New LS1 Owners - Newbie Tech - oil pressure...
camaroboy14
01-11-2010, 08:22 PM
When my car is at idle what pressure should it be at? Also when I am driving normal?and when I am kind of stepping on it?
tdevil55
01-11-2010, 09:09 PM
This is all when car is warm and ready to drive.
IDLE: Around or just slightly above 40
CRUIZING: Around 60
WOT: Never looked, but close to or just past 60
This is just my observations on my 02 a4.
camaroboy14
01-11-2010, 09:48 PM
Ok thanks man, just wanted to make sure I am cool
Myrdhyn
01-13-2010, 10:43 AM
My 99 M6 Does the same as tdevil55s at idle/cruising, but at WOT it climbs up to nearly pegged as the RPMs climb towards the redline. I'm actually trying to find out if that's normal or not, should my oil pressure climb to like 80at WOT and high-ish (5k?) rpms?
camaroboy14
01-13-2010, 12:07 PM
Mine does the same, that's kind of why I started this thread. So does any one know if its normal?
USArmyZ28
01-13-2010, 12:44 PM
Yes its normal, mine does it everytime and no problems. Keep your oil level in check.
tdevil55
01-13-2010, 12:54 PM
I havent really done many WOT runs on mine yet, and when I have, I wasnt watching the oil gauge, but I would think that is normal. The more the engine is turning, the more the crank is turning, then the more the oil pump is turning, so this would cause the oil preassure to rise. Again, I really never paid attention to how high my preassure was at WOT, but I would assume it would go higher. Is this with a stock oil pump, or is it ported?
Myrdhyn
01-13-2010, 01:40 PM
Yeah, mine does it every time, and now that I think about it it makes perfect sense. I've had the car since September, and if I'm doing a quick WOT burst my attention is usually split between the road ahead (90% of my attention) and the tach (the other 10%). So I never noticed it until a week ago when I was sitting funny due to sore back and it was more central to my vision when I looked down.
Glad to see it is normal AND I'm not the only one that freaks about little stuff like this :P
camaroboy14
01-13-2010, 05:46 PM
Mine is stock. Also your not a freak you just love your car, and a smart driver, like all of us....
carwatcher
01-13-2010, 06:14 PM
Mine sits a hair above 20 at idle, climbs up to 60 when doing around 70mph. I checked the oil and it's full, I don't know why it goes to 20.
thirdgengta350
01-15-2010, 11:10 PM
20 at idle Imo is a little low. you might wanna run a little thicker oil. or check into your oil pressure sender. or your pump.
slayerized6
01-16-2010, 09:12 PM
im having the same problem. turns out the pressure relief valve on my oil pump has a weak spring and is opening/closing at the wrong time. also fluctuates at cruising speed. thunder racing oil pump is going in next week
ae13291
01-16-2010, 10:05 PM
i had a fluctuating guage turned out to be a oil pressure sending unit
ae13291
01-16-2010, 10:08 PM
btw the stock pressure releif spring is set to 65 psi give or take. and yes it is normal for the guage to climb that high my High olume pump sets my psi at 60 on idle and the relief should be around 72 psi
02WS6SSZ71
01-17-2010, 01:04 AM
I think the min specs are 10PSI per 1000 RPMs, so 20 at idle isn't necessarily bad if it's always idled at that. If it stays at 20 upon exceleration I would be worried.
Fifedogg
01-17-2010, 12:22 PM
Mine gets to about 25 at idle when the car is hot and the oil is thinner. 20 isnt bad as long as your oil pressure goes up to 60 or so at WOT.
slayerized6
01-17-2010, 01:12 PM
Oil Pressure (Minimum-Hot):
At 1,000 rpm 41 kPa (6 psig)
At 2,000 rpm 124 kPa (18 psig)
At 4,000 rpm 165 kPa (24 psig)
source: alldata
