1994 B4C, Built 396 LT1 Supercharged, what's it worth?
Hey there,
Well I'm curious if you guys could help me determine a ball-park figure of what my car would be worth if I put her up for sale. Below I'll list the bulk of mods off the top of my head. There's only about 10k miles on the Engine and Transmission, since both of them have been built. The rear-end is a stock unit with 60k on it.
This thing is pretty much a project mostly finished, that is daily drivable, but needs money thrown at it to live up to its potential. I've had the car 9 yrs, ever since I was 16.
My plans to finish it were upgrade A-trim to T-trim (A-trim is maxed out making barely 4lbs...it was originally used when the engine was stock making 7lbs). Ford 9-inch or 12-bolt, Needs new brakes, and finally a dyno-tune. It's running off a PCMForLess Tune that's been re-done a couple times. Excellent tune considering it's mail-order. Plan was to put it on a dyno loooong ago as soon as I put a T-Trim on. I can post pictures if it helps. Car is pretty clean, all black paint, black wheels, smoked taillights etc. No added body work. Somewhat of a sleeper with the single-tip exhaust and no badges. Interior behind front seats is fully gutted. Full interior front seats forward. Displacement adds up to 396 cubic inches, or roughly 6.5 liter.
It's a 1994 B4C, with 164k miles on the Chassis. Most aftermarket parts (including suspension etc...has 10-20k miles on them)
Laundry List:
Shortblock:
Callies Dragonslayer Crankshaft, (Forged w/coated journals) (3.875in stroke)
Eagle H-Beam Connecting Rods (Forged) (6.000 length)
Diamond Blower/Turbo Dish Pistons (Forged) (Rings, wrist pins, etc all from Diamond)
Billet 4-bolt splayed Main Caps
ARP Main Studs
ARP Connecting Rod Bolts
Original LT1 block that came with the car from the factory:
-Heavily clearanced for added stroke
-Bored .030 over
-Converted to 4-bolt 22-degree splayed main-caps
Moroso Oil-Pump Driveshaft
Thunder Racing Keyed Crankshaft Hub
Heads & Valvetrain:
Fel-Pro 1074 Head-Gaskets
Stock Aluminum LT1 Heads (Re-surfaced, re-built w/stock valves & new seals)
ARP Head Bolts
GM LT4 Valve Springs
GM LT4 Hotcam Camshaft
GM LT4 Aluminum 1.6 Ratio Roller Rockers
GM LT4 Titanium Retainers
GM LT1 Push-rods
GM LT1 Lifters
GM Heavy Duty Timing Set (Sprockets & Chain)
Ignition:
GM LT1 Opti-spark Distributor
MSD Blaster Coil II
MSD 6A Ignition Box
10.4 mm Taylor .406” Pro Race Wires
Rest of Long Block, Exhaust, Intake, (Odds and Ends):
Hooker Long-Tube Super Comp Headers (equal length primaries)
DEI Header Wrap
Custom 3in Y-pipe to single exhaust w/36in muffler
1LE AC Delete Pulley (A/C system completely removed)
Bosch 42lb Fuel Injectors (Ford Racing “Green Tops”)
T-REX Fuel Pump (In-line out-of-tank)
Mr. Gasket Crankcase Evacuation System
Boost Cooler “Gas Stage 2” Alcohol/Methanol Injection System
-150psi pump
-625ml/min nozzle
-Boost Cooler electronic boost referenced injection computer
GM LT1 Electric Water Pump
Stock LT1 Intake Manifold
Stock LT1 Throttle Body
SLP Throttle Body Airfoil
Vortech V-1 Supercharger A-Trim Kit
-Installed 3/22/06 Approx. 153,000 miles
-Brackets/Pulleys/etc.
Vortech Aluminum intake Elbow
K&N Air Filter
T-Bolt Hose Clamps
Transmission to Rear-end:
XSTREAM/STRIP 4L60E Built by MegaMax Trannys
-Beast Sunshell
-Billet Servo’s
-Lengthened servo pins
-Kevlar Bands
-Rabesto’s Z-pack clutches
-29 element Dual Caged Input Sprag
Rebuilt/Freshened up w/new cluches, bands, input sprag, and rear planet 08/21/2007
Flex-A-Lite Tranny Cooler 20,000 GVW
GM18A-HP High-Performance High Stall (2100-2400) Torque Convertor 08/21/2007
GM LT1 Rebuilt/Balanced Driveline w/greasable Heavy Duty U-Joints
GM 10-bolt stock rear-end w/3.23 Gears (Stock Auburn Carrier w/posi)
Suspension/Wheels/Tires:
Eibach Sportline Springs
KYB AGX Fully Adjustable Shocks
(2) 17in AT Italia Riva Wheels Custom Painted Black
- w/315 series Nitto 555R Drag Radials
(4) GM Factory Magnesium Corvette C5 Wheels (staggered 18in rears; 17in fronts)
- w/285 series Pirelli tires rear
- w/235 series Pirelli tires front
(4) GM Factory Camaro Wheels Custom Painted Black 16in x 8in (Original wheels)
- w/215 series snow tires
Interior & Electronics:
Stock PCM/ECU Tuned by PCM ForLess ECU Tuners
Scanmaster LT1 PCM Scanner
Recaro Touring Seats
Boost Gauge
Sony Deck
Sony 10-disk CD changer
Thanks ahead of time,
-Andrew M.
Laundry List:
Shortblock:
ARP Main Studs
-Bored .030 over
Heads & Valvetrain:
ARP Head Bolts
GM LT1 Push-rods
GM LT1 Lifters
Ignition:
MSD Blaster Coil II
MSD 6A Ignition Box
DEI Header Wrap
-150psi pump
-625ml/min nozzle
K&N Air Filter
T-Bolt Hose Clamps
-Beast Sunshell
-Billet Servo’s
-Kevlar Bands
Boost Gauge
Sony Deck
-Andrew M.
BTW: reason for potential sale...considering going back to college to get second degree. Will need the money to fund the gap that student loans and grants won't cover.
Oh and...I have all receipts for all Machine Work, All Parts, everything...detailed documents on what machining was done, how it was done, etc. etc. Machining, balancing and assembly of Short Block was done by R&Q out of Selah WA. They are very reputable in the area. Receipts for everything add up to 15-20K i believe (but thats tires and all sorts of little things no longer on the car) I have documents from everything since I was 16. I even have hundreds of pictures of the build process.
Last edited by AmericanMuscle33; 01-12-2010 at 01:48 AM. Reason: Forgot to mention reciepts.
I couldn't find a picture of it with the Magnesium C5 wheels...but the rest is the same...you'll get the idea. Oh yeah, and the windows are all tinted to legal maximum in WA.
The static compression ratio is just a hair under 9:1. At 4 psi w/drag radials it ran:
60': 1.674
330: 5.026
1/8: 7.807
MPH: 87.48
That's the first and last time I had it at the track after the motor was broken in. It's never been dyno'd, otherwise I'd post numbers. As it sits there should be quite a bit of power sitting on the table you could grab with a dyno tune. For starters it's not tuned for the methanol. I added that on later and it's turned down just to ensure detonation doesn't occur. Although the blower is maxed out, with a tune I imagine you could bump up timing, add meth or water, and just generally improve over the mail order. I approximate power to be in the 500hp area at the flywheel, same with tq; as it sits.
What do you guys think? Any suggestions?
Part of me thinks I'd potentially be able to get more money if I paid to have it dyno'd. Seems that may help to prove overall health of the motor and power potential. Any truth to that, or am I just throwing away more money?
I was hoping for the 7k - 8k neighborhood, does that sound reasonable?
60': 1.674
330: 5.026
1/8: 7.807
MPH: 87.48
