Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c5z water everytime it rains in the trunk????
Old 01-12-2010, 07:14 PM
c5z16z's Avatar
Default c5z water everytime it rains in the trunk????
i have a big problem ....everytime that it rains i always get water in my trunk passengers side can somebody help?????
Old 01-13-2010, 12:15 AM
GNon18s's Avatar
Same here. Appears to drip from the base of the rear window when I wash it.
Old 01-13-2010, 12:45 AM
SStheBest's Avatar
Seal!!!!!!
Old 01-13-2010, 08:28 AM
blackassassin's Avatar
Yeah i would look at the front seal in the trunk. Or put some paper in the trunk wash the car and see what spot on the paper has the most water.
Old 01-13-2010, 08:31 AM
c5z16z's Avatar
Originally Posted by SStheBest
Seal!!!!!!
so you would say to replace the seal on the trunk lid....??? or the rear window seal...???thanks guys......
Old 01-13-2010, 12:30 PM
~JOSHUA's Avatar
FRC's leak both in the front and the back.... do a search in the C5Zo6 section on corvetteforum and you'll have tons of reading.
After a quick search... there's MANY more threads
http://forums.corvetteforum.com/c5-z...king-z06s.html
http://forums.corvetteforum.com/c5-z...al-places.html
http://forums.corvetteforum.com/c5-z...r-leakage.html
http://forums.corvetteforum.com/c5-z...h-pillars.html
http://forums.corvetteforum.com/c5-z...ater-leak.html
http://forums.corvetteforum.com/c5-z...trunk-lid.html
http://forums.corvetteforum.com/c5-z...in-02-z06.html
Old 01-18-2010, 08:22 AM
triche's Avatar
I'd check the drain tubes in the trunk area first. maybe you have a lot of crap built up in there.
Old 10-31-2016, 03:32 PM
Taylen Ceccacci's Avatar
Default check trunk hinge bolts
The trunk hinge bolts on mine work themselves loose and let water leak past like crazy. Probably just need to hit all 4 with a dab of silicone or something.
Quick Reply: c5z water everytime it rains in the trunk????
