347 in the 5's ?
Old 01-12-2010, 10:37 PM
19trans_am98's Avatar
Default 347 in the 5's ?
ok guys here's the scoop as of now i have a 347 shortblock....stock crank forged h beam rods and wiseco -11cc dish pistons....needing advice on what heads & cam to go with....topped of with a vic jr and a 90mmtb....and a master power mp4598 turbo....we have a lot of guys running an 8.5 tire class around here....needing to get this car into 5.60's in the 1/8th....what do you guys think? i know that the turbo will have to be changed but im looking to get the bugs worked out with this small turbo then step up to a bigger one say a 80-88mm?
Old 01-12-2010, 11:48 PM
black98ws6ta's Avatar
It is definitely possible, my car has been 5.96 on a stock shortblock/heads and 60'ing like a turd. If the car is light enough you could go that number on fairly small turbo.
Old 01-13-2010, 09:01 AM
LS1TECH Sponsor
DrTurbo's Avatar
You will need an 88mm unit to reach that level of performance. A MP unit will not make any power close to what you need. If you push it, then expect it to come apart.
88mm is good for solid 5.4's with a properly set up car. And faster if everything is perfect.
Old 01-13-2010, 11:50 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I went 5.9 with my old setup, and I pretty much didn't know what I was doing.
I'd buy aftermarket heads with a thicker deck they won't lift as easily as stock heads.
Old 01-15-2010, 01:52 AM
Sandmann120's Avatar
What are some other 5 sec 347 combos? Anyone do it on spray much?
Old 01-16-2010, 12:50 PM
What size turbo? Any more details on your build?
Old 01-16-2010, 07:28 PM
kp
kp's Avatar
I've had two in the 5s with a 347, LS6 intake, smallish cam etc but I used a procharger.
60' is the tough part when looking for 5.60s, I'm sure its possible with the right turbo and a light enough car.
Old 01-16-2010, 11:49 PM
Good to know. been trying to decide whether or not to leave mine as a nitrous setup or go turbo. Looking for 5's to be competitive in a local 'street car' class here in Iowa. Mid 5's should get me solidly in the field.
Old 01-17-2010, 09:42 PM
Josh@PremierAutosports's Avatar
Does the class limit you to a certain size turbo wheel limit or pill size?
Old 01-17-2010, 10:38 PM
Not at all. Any engine combo, any power adders. Stock style suspension, no wheelie bars, drag radial or 10.5 tire. Low payout to keep out the heavier hitters.
Old 01-18-2010, 01:23 AM
Turbo was a s480, here is the biggest collection of info I have on the car.
https://ls1tech.com/forums/forced-in...hortblock.html
Quick Reply: 347 in the 5's ?
