HELP LS6 manifold install no oil presure on gauge
Old 01-13-2010, 08:00 AM
kb274868123's Avatar
Default HELP LS6 manifold install no oil presure on gauge
I just did an LS6 intake swap on my 99 firebird LS1 and i believe the oil pressure sending unit might be broken. When i removed the old manifold the Oil pressure sending unit was still intact and looked to be fine. One thing that did bother me when looking at it was that the wiring that is attached to the connector that plugs into the sensor, only had one visible wire. Does anyone know or have a schematic on how many leads go into the connector that plugs into the oil pressure sending unit? I took it for a drive after the install and it does not seem to be leaking oil. Also for future reference incase i have to take the whole thing appart, does the break booster tube that is connected to the elbow on the LS6 intake manifiold run behind or infront of the Oil Pressure Sending Unit? Thanks for the help.
Old 01-13-2010, 08:12 AM
ramairracer's Avatar
sounds like it might have broke, if i recall 99+ were one wire sensors while 98s were 2 wire sensors,
Internet Mechanic
BlackScreaminMachine's Avatar
Kinda of a stupid question, does the guage register anything inside the car??
Old 01-13-2010, 08:18 AM
When the car is off the needle slightly raises above zero. When the key is turned just for power or when the car is on, the needle pins to zero indicating no oil pressure. Is there another way to check if i am actually getting oil pressure without that gauge?
Old 01-13-2010, 08:45 AM
redbird555's Avatar
Had the same thing happen to me my oil sensor was fine but the one wire and yes it is only one wire was broken near the cowl when I pulled thee intake out so inspect it carefully.
Old 01-13-2010, 08:47 AM
Internet Mechanic
If it is Zero and Read Before the install. It's broken.
Old 01-13-2010, 08:55 AM
Alright i will have to check the wire and make sure that there is still a connection. Is it alright to still drive the car if the oil pressure sending unit is broken and how can i check/confirm that i am still getting oil pressure without the use of the gauge on the dash? Thanks
Old 01-13-2010, 12:38 PM
wytry's Avatar
I'm sure you're getting pressure, you just broke the sending unit. Whether you pulled the wire out, or broke the goddamn thing in half (like I did), it probably just needs replaced. 38$ fuckup. But I believe I needed a special socket to remove it, which my neighbor happened to have
Old 01-13-2010, 11:40 PM
venom346's Avatar
The socket, I bought from kragen, it was about 9 bux, if i can recall.
Old 01-14-2010, 01:22 AM
xRelapse13's Avatar
if you broke it then after driving it for awhile u will start leaking oil. Happened to my friend when his broke. after a week or two he got a mysterious oil leak.
