???Super Short Belt Mod.....
what size belt would i need to run a belt from a 25% underdrive crank pulley to the alternator only???
is BMR the only company that makes the adjustable alt bracket???
.....if not, what other company makes an adjustable alt bracket???
you have the adjustable alt right now? with the tensionor, 50.5 is coing to mind? I bought one but can't steer anymore one hand with it. Stock pulley was 51.5 I belive.
you have a race EWP? and dont need the belt for that too? if not buget just run it up to the tensionor , and take the PS off. you probally already now this
back to my original question, i was asking what size is the super short belt with UD pulley. which i researched already and believe it is 30.5
The BMR instructions tell you the belt length for stock and underdrive pulleys. I used the one that the instructions recommended but had to do some serious cussing to get it on there, as it was a touch on the tight side. Once on it was fine and did not bottom out the adjustment. I am running the BMR bracket with a powerbond UDP.
Here you go: http://www.bmrfabrication.com/INSTALL/AB001.pdf
The instructions do say 30.5. I ordered the gates belt with the number they have listed.
I mounted the OEM tensioner in reverse (used one bolt to hold it against the alt bracket and the interference with the alt bracket kept it from rotating)
the bmr bracket is probably a good way to go though...but this way was free
My belt was 38" long but the crank pulley was close to OEM diameter (maybe 10% UD)
Make GEO
Model STORM
Beginning Year 1991
Ending Year 1993
Engine Type L4
Liter 1.6
CID 98
Engine Size 1.6L/98
Engine Family Suzuki 4-cylinder
Belt Fitment Power steering, without A/C
Make GEO
Model STORM
Beginning Year 1991
Ending Year 1993
Engine Type L4
Liter 1.6
CID 98
Engine Size 1.6L/98
^^^props fireball for the free way to do things. that actually doesnt look bad at all and being free is another plus...but ya im just gonna go with the BMR alt bracket...no offense
Race your car!
I tried it the way you had it set up Fireball, but hte tensioner wasn't sitting flat and it kept throwing the blet at idle... I ended up buying the BMR one because I couldn't get the thing to line up right, as soon as I tightened the bolt the tensioner kept getting pushed to one side, never really did figure out why, just stopped fighting with it before it gave me a complex
it would NOT work that way. the belt wouldnt even touch the waterpump pulley. the belt has to wrap under (backside touching) the waterpump pulley. u have to keep the tensioner for the stock waterpump
