alternator/power steering brackets????????/
Old 01-14-2010, 07:21 PM
imeem-'s Avatar
Default alternator/power steering brackets????????/
can anyone tell me if i can use gto or camaro brackets on my 1998 corvette engine to move the alternator and powersteering
Old 01-14-2010, 07:40 PM
cyamaha2007's Avatar
if you used the camaro brackets the acc. would stand off the block too far and the belt wouldnt stay on. You would have to replace all of the brackets the water pump and crank pulley if i remember correctly.
Old 01-14-2010, 09:36 PM
imeem-'s Avatar
thanks alot!!! any other feedback helps guys , im new to these engine
Old 01-14-2010, 10:28 PM
imeem-'s Avatar
ls1 2 and 6 is the same water pump i believe , could i switch everything to camaro brackets and pumps ?
Old 01-15-2010, 06:50 AM
Pop N Wood's Avatar
This is a good article that explains LS accessories
http://www.carcraft.com/techarticles...ide/index.html
Old 01-15-2010, 05:20 PM
NemeSS's Avatar
easiest way to to use all of the matching accesories with crank pulley used.
Old 01-16-2010, 12:09 PM
imeem-'s Avatar
couldnt thank you more guys i appreciate it
Old 01-16-2010, 06:54 PM
69AMX364's Avatar
Do not forget kwik performance.
Quick Reply: alternator/power steering brackets????????/
