anyone converted a 2008 LS3 M6 e38 HPtuner tune for a e67 ECM
Old 01-15-2010, 04:59 PM
nycblazer's Avatar
Default anyone converted a 2008 LS3 M6 e38 HPtuner tune for a e67 ECM
anyone converted a 2008 Corvette 6.2L LS3 M6 e38 tune for a e67 ECM using HPTuners
I have a 2008 LS3 engine in my 1999 chevy blazer with a custom made engine harness with a 3 plug e67 ecm.
I have the stock tune for the LS3 M6 but its for a E38 2 plug ECM
I just need a stock tune for the LS3 M6 running a E67 3 plug ecm.
I also have HPTuners Pro.
Can someone Help with that tune, thanks
Old 01-15-2010, 05:11 PM
LS1TECH Sponsor
foff667's Avatar
Someone correct me if I'm wrong but I don't believe there is such a thing.
Stock ZR1 file is likely the closest you'll find in that regard.
07+ TBSS ran an E67 but they were auto
Old 01-15-2010, 05:18 PM
nycblazer's Avatar
true the closest i'll get might be a 07-up TBSS tune and just switch from auto to manual using the HPTuners or transfer everything from the E38 LS3 vette tune over to a E67 TBSS tune file. is that possible?
Old 01-16-2010, 01:50 PM
LS1TECH Sponsor
foff667's Avatar
You'll only be able to transfer over what is visible though ie maybe 500 or so tables give or take.
Old 01-18-2010, 03:14 PM
nytoolmkr's Avatar
what about a 07 CTS-V......LS2 and 6spd manual?
Old 01-19-2011, 07:31 PM
nycblazer's Avatar
what ECM does the Cadillac CTS-V use.
Does it use a E38 or a E67
Thanks
Old 04-04-2022, 04:27 PM
cpd004's Avatar
Curious if you ever sorted this out...Toying around with something similar at the moment as far as an E67 LS3 and automatic when it was previously an E38 and T56 from an '11 Corvette.
Old 04-04-2022, 04:30 PM
Received 3,018 Likes on 2,349 Posts
If by "you', you mean "nycblazer", he hasn't been here for 3 years.
Old 04-04-2022, 05:12 PM
cpd004's Avatar
i do and saw that prior to replying. Thank you.
Quick Reply: anyone converted a 2008 LS3 M6 e38 HPtuner tune for a e67 ECM
