I'm about to pull the trigger on a set of bmr trailing arms/control arms
With these trailing arms your able to adjust the angle of the rear end right? also this is strictly a street driven car but I would like alot of adjustability. All my suspension is shot http://www.bmrfabrication.com/controlarms/MTCA002R.jpg
These will allow you to adjust the rear end in one direction(Front to back)
Essentially this allows you to move the tire forward or backward in the whel well.
Which way do you want to move the rear?
From side to side of the car you need a PHB. If you want to adjust the pinion angle you need a Torque arm.
~Jim~
~Jim~
