Has anyone installed Budzter coil spring height adjusters
Old 12-20-2003, 07:58 PM
WARNING: BAD TRADER STATUS
TWISTA TA's Avatar
Default Has anyone installed Budzter coil spring height adjusters
Has anyone installed budzter coil spring ride height adjusters? If so how hard was it to grind the lip off your differential to bolt the budzter's on? Has anyone used the spacers so they didnt have to grind the lip off? If so how much height did this add to the rear of the ls1?
