Gear change with LS1 Edit
I just got a new 9 inch put in. I had 3.42 gears stock in the M6 and now have 4.11's. I was wondering before I get the gear ratio adjusted, what is the speed difference. For instance If it reads 70 am I going actually faster or slower since the PCM is programmed for 3.42's. If you know what the exact MPH difference is also would be great.
Next I wanted to know is there a cheaper way to getting gear change done rather than a local shop charging 150 bucks just for a gear change with ls1 edit?
Guest
Posts: n/a
if you are as serious as putting in a ford 9", go get EDIT unless you plan on changing to a different fuel management system. you will gain many other benefits from having it. a scan tool of some sort (EASE, ATAP, etc.) would top off the package perfectly.
