pro stars on 99 camaro
Old 01-18-2010, 09:32 PM
slolt1's Avatar
Default pro stars on 99 camaro
will the 15 pro star fit with stock brakes front and rear i dont mind grinding just dont want to have to do a lot of grinding
would be 15x4 or 15x3.5 on the front
15x10 on the rear
i would like to see some pics if any one has them
thanks
Old 01-19-2010, 08:35 AM
wheelczar's Avatar
I would go with the 15x3.5. Seems a lot of guys on here use them without grinding. On the rear you can go with a 15x10 with a 7.5 back space. Would look great!
Old 01-19-2010, 12:35 PM
chrysler kid's Avatar
you have to grind a good amount on the fronts in order for the weld pro stars to fit. i would personally buy the summit front runners and purchase the weld 15x10's used. the summit fronts dont need to be ground as long as you run a spacer where as the welds do
Old 01-19-2010, 03:16 PM
Camaro396's Avatar
The Summit fronts are made in China pieces of heavy ****. Might as well leave your stock wheels up front, you wont save any weight worth talking about with those heavy cast wheels.
I ran 15x3.5 fronts with no grinding, just a tiny spacer in the front. However for the rears, you will have to do a lot of grinding. It can be done, I used to have Prostars on my car.
As for pictures, look around. There's about 6,300 cars on this site with them.
