Gas pump shutting off while filling up?
Old 01-19-2010, 03:01 PM
Daredevil_TA's Avatar
Default Gas pump shutting off while filling up?
I know this problem has been addressed before but I havent been able to find it so I thought id start a new thread. Basically, my car sat for a year an last night I went to put gas in it and had a hard time filling it up, once it got to about 10 gallons the pump kept shutting off like it was full but it wasn't. I think it might be something with my EVAP/charcoal canister? but I dont know much about it, what do you guys think?
Old 01-20-2010, 12:41 AM
c'mon someone has got to know about this problem
Old 01-20-2010, 01:13 AM
lazyhomie's Avatar
I'm having a similar problem too... Would be interested in any input
Old 01-20-2010, 05:02 AM
myk
myk's Avatar
Some gas pumps have some sort of new-fangled nozzle or whatever that helps to deal with vapors or something, so it may not even be your car. Your problem happens to me every once in a while also. What I do is pull the rubber part that covers the nozzle back as far as I can, and then insert the nozzle into the filler tube. Try that...
Old 01-20-2010, 06:04 AM
eseibel67's Avatar
Don't ram the nozzle all the way down the filler neck. Back it out a couple of inches when filling and listen carefully. When you hear the gurgling getting closer stop the pump manually to avoid a stinkin' mess.
Old 01-20-2010, 10:13 AM
Interesting...I have noticed it happens alot more with Shell gas stations
Old 01-20-2010, 12:24 PM
sscamaroburn02's Avatar
my camaro doesn't have this problem but my other car I DD does. and like you said it happens more at shell stations than it does at others. I'm really not sure how to fix it but I do think it has something to do with the actual pump itself and not your car. My buddies car also does the same thing. I would try and find a station that works the best and stick with that one
Old 01-20-2010, 12:40 PM
Super-Bat's Avatar
I've had this issue at Texaco as well.
Start pumping, take a step back and it stops. Start again, take a step back and it stops. Move nozzle back a little, start it again and it's fine till it's full.
Old 01-20-2010, 01:27 PM
I'll try another station and see what happens, just wasn't sure as my car did sit for a long time an this was the first time I have filled it up.
Old 01-20-2010, 05:18 PM
Spartan7's Avatar
The newer pump nozzles are a lot more sensitive than the older ones. The slightest vapor leak will trip them. Just pump your gas slower.
Old 01-20-2010, 05:22 PM
ae13291's Avatar
i usually hold the nozzle higher and it works.
Quick Reply: Gas pump shutting off while filling up?
