What's wrong?
What's wrong?
Ok, every now and then when I start my Camaro the odometer resets and all the guage needles sweep. I check my radio and all the stations are still programmed in Everything seems tight on the battery. My other problem is my O2 sensors. I tried several different O2's on my driver side and none of them seem to work. I even have a brand new Bosch 13111 and it still doesn't work. I cleaned the connector with electrical cleaner with no luck. What do you guys think the problems are?
i remember hearing the answer for the gauge sweep and odometer reset, or at least reading about it in my service manual.
if it doesn't get posted, PM & email to remind me and I'll look it up for you when i can,
it would not be a sign of a failing alternator, since it's happening when the ignition key is turned to run and the engine is not running = alternator not spinning.
