which combo for 200 shot all day long?
6.0L IRON SHORTBLOCKS
370 IRON SHORTBLOCK PACKAGE: $3,750.00
6.0L Iron 4.030" Bore Block
GM 3.622" Crankshaft
Callies Compstar 6.125" Forged Rods
Forged Lightweight Pistons & Moly Rings
Clevite H-Series Bearings
ARP Main Studs
Internally Balanced Rotating Assembly
Fully Assembled Short Block
OR
376 L92 SHORTBLOCK PACKAGE: $4,500.00
L92 4.070" Block
GM 3.622" Stroke Crankshaft
Wiseco Lightweight Pistons & Moly Rings
ARP Main Studs
OR
416 L92 SHORTBLOCK PACKAGE: $5,600.00
more than likely, the least durable combo, right?
L92 4.070" Block
Callies Compstar 4.000" Stroke Crankshaft
ARP Main Studs
i know that the rings will have to be changed to a nitrous friendly set. will the piston brand be ok or should i request diamonds? i'm using my ls6 cnc gmpp heads with the light weight valves and i have to pick a cam for the iron block and the l92 416 choices. i already have a cam specd for the 376. i'll be using my current free flowing exaust, no cats. would you change anything else?
thanks in advace for any input guys!
ARP Main Studs
OR
L92 4.070" Block
ARP Main Studs
OR
L92 4.070" Block
ARP Main Studs
