Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
My rebuilt rear diff setup
Old 01-20-2010, 10:17 PM
stkshkr's Avatar
Default My rebuilt rear diff setup
Should hold up well
Corvette C3 diff went from 4:10 to 3:90
Old 01-20-2010, 10:33 PM
itsslow98's Avatar
nice, how much did that run you? more info on your motor setup too please
liqidvenom's Avatar
wait one sec.... this was dropped into you v? am i missing some details some place?
Old 01-20-2010, 10:40 PM
stkshkr's Avatar
Motor is a Maggied LS6 383
The rear was fabbed about 2 years ago by Doug (O5CTSV) in Ohio, it was one of two he made using a Corvette C3 diff modified for use with the IRS. The other car was sold because of noise and other problems. The rear end probably had 200 passes on it and I was breaking half shafts and shattering u joints on them like they were made out of glass. This not only got expensive but always limited the launch to about 2 grand( although I did have a 1.60 60' one time.... breaking a half shaft). Jim Unger Racing (a chassis shop) in Dayton OH did the rebuild, I took it there because all the welds on the supports were broken among the other problems. First thing he noticed was the negative pinion angle and the lack of sufficient support for the rear (I knew that because of the bowed support plate. He's done a great job and I now believe it's unbreakable and set up to perfection. The sub frame connectors and rear cradle are all tied in together to finally work together. I will be glad to finally do the 5000 RPM launches on the 2 step I've always wanted to do!!!
BTW it's still the fastest Maggie powered CTSV.... 11.85 and I expect to drop that quite a bit when I get back
Old 01-20-2010, 10:46 PM
liqidvenom's Avatar
what did that wind up costing for the rear setup
Old 01-20-2010, 11:05 PM
Roidz24's Avatar
Wow that's cool, but probably pretty cost a bit.
Old 01-20-2010, 11:15 PM
stkshkr's Avatar
More than anyone in thier right mind would pay.............
Old 01-20-2010, 11:18 PM
SkullV's Avatar
I figured you were going to keep that figure hush hush!
Old 01-21-2010, 12:36 AM
itsslow98's Avatar
looks expensive but hey as long as you enjoy it, nothing ever goes right the first time it seems and NOTHING ever costs what you expect it to
Old 01-21-2010, 05:05 AM
maxspeed96ct's Avatar
Looks badass
Old 01-21-2010, 07:58 AM
liqidvenom's Avatar
i still dig it. go hunting for faster times.
Old 01-21-2010, 04:53 PM
Tainted's Avatar
pending for price....
Old 01-21-2010, 06:35 PM
lilgcts-v's Avatar
i would think with 60 foots that low you would be able to crack lower then an 11.85
Old 01-21-2010, 06:53 PM
SoJersey05V's Avatar
wow nice setup... how are you still driving stick with one leg and one arm??? lol (cost an arm and a leg i'm sure!) <--- gay *** joke i know!
Old 01-21-2010, 06:55 PM
liqidvenom's Avatar
the one time he pulled a 1.6 he broke down. so im sure his times will get quicker.
Old 01-21-2010, 08:50 PM
DoctorNick's Avatar
What was done to prevent the halfshafts and u joints from snappin?
Old 01-22-2010, 09:38 PM
1BADCTS's Avatar
Wow, that looks like a VERY well engineered setup. Good luck at the track, and don't be shy posting your progress next season!
Old 01-23-2010, 02:11 AM
stkshkr's Avatar
Yes, had to baby it on the launch or KAPOW
Old 01-23-2010, 02:15 AM
stkshkr's Avatar
That was one 60' with a break. Moving 2 tons quickly ain't easy........
Old 01-23-2010, 03:13 AM
2003RC51's Avatar
Are you just dumping the exhaust where it is in the pic? Looks like it would have to drop pretty low under that bar, maybe a couple inches off the ground?
Work looks really good.
Quick Reply: My rebuilt rear diff setup
