Manual Transmission - Clutch advice
Guitarslinger41
01-21-2010, 12:02 AM
So I've got a '99 Z-28 and it REALLY needs a clutch. I've been doing a lot of research and it seems most guys are using Spec stage 3+'s in their cars. Sadly, I'm too broke to afford one and it needs to be replaced SOON. I've seen Stage 1s for around $250 and Stage 2s for around $380. I wanted to know if any of you guys have had experience with either of these clutches and to share your thoughts. Thanks!
teke184
01-21-2010, 07:14 AM
what power level do you need to hold?
Guitarslinger41
01-22-2010, 01:22 AM
Its my DD, so stock power levels with room to grow with bolt ons and such
The Manalishi
01-22-2010, 01:28 AM
Get a LS7 clutch kit. It will do what you want.
Guitarslinger41
01-22-2010, 01:46 AM
I havent been able to find an LS7 clutch kit for sale, how much are they?
The Manalishi
01-22-2010, 02:13 AM
I got mine from Scoggin Dickey. They are a sponsor of the site and there are several other sponsors that sell them. They are $459 for the clutch kit and the flywheel on SD's site unless you want an aluminum flywheel and then its $559. Of course you can check the other sponsors and maybe beat that price but I liked the way SD took care of everything I ordered from them. You have to get the flywheel since the LS1 flywheel won't work with the clutch.
teke184
01-22-2010, 06:34 AM
ls7 is HEAVY....sucks up power
get the light flywheel to help make up for it
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
