windage tray ..options?
Ran into an issue this afternoon during my project.
I bought an LS1 off a guy who was using a Dwayne Due subframe that cause him to put a truck pan & windage tray on the motor due to crossmember placement.
well, with mine I needed to switch back to the Fbody. I bought a new oil tank & pickup tube but not the windage tray. Obviously the truck tray - since it goes all the way to the timing chain - isn't going to work with the Fbody pan..I want to drop my motor in tomorrow and don't feel like chasing down a windage tray.
Think I can just cut it to the length of the Fbody tray? or are they so different that I would cause a problem?
so cutting the windage tray fixed the problem? I'm in the same boat and would rather trim mine as long as it doesn't cause any issues.
Does anyone have the camaro windage part number handy just in case?
I didn't get a quick enough answer so I decided to modfiy my 5.3 tray....I cut off part of the front section like the picture and had to notch out a spot where the pick bracket mounted for clearance....worked like a charm.
Thanks
Thanks
