fluids question
fluids question
flushing out the cooling system after a head gasket went bad. My question is would it be ok to use only distilled water in the system to work out the crap before i return to the DEXCOOL fluids.
LS1Tech Administrator
Received 1,483 Likes
Distilled water is the ONLY water you should ever put in the system.
And yes, it's fine to run straight water (distilled) so long as you're in a climate where it doesn't get below freezing.
