Safety loop w/ lowered car
Old 01-23-2010, 02:40 AM
lemons12's Avatar
Default Safety loop w/ lowered car
Pulling into the car wash today I bent the hell out of my BMR safety loop. I am wondering if there is another brand that tucks up tighter.
I have Kooks LTs with ORY and am lowered 1" on BMR springs. Nothing EVER scrapes except for the safety loop.
Thanks in advance!
Old 01-23-2010, 07:26 AM
Intercooler2's Avatar
I have the Lakewood on mine. How much lowered are you? I will tear the bottom of my car off before ever hitting that loop.
Old 01-23-2010, 11:18 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
i have a 1 piece loop that is a bolt-on and nothing hangs low. should work with your exhaust and torque arm.
Old 01-24-2010, 05:38 AM
the_merv's Avatar
Is it bolted to the Tunnel Brace area?
Old 01-24-2010, 10:53 PM
lemons12's Avatar
1"... If anything ever hits, its the safety loop. I rarely scrape but I would rather not scrape at all. It is only on steep parts that I have to take a bad angle at for some reason. The kooks tuck up very nicely.
It slightly bent those bracket also, but not enough to matter I don't think.
I honestly haven't had a chance to inspect it fully yet, have been busy moving and with work.
(That is not my car)
Old 01-24-2010, 11:17 PM
RooRnZ28's Avatar
what does the price run on these?
Old 01-24-2010, 11:20 PM
lemons12's Avatar
PM sent.....
Old 01-27-2010, 07:34 AM
NXZ28's Avatar
The Lakewood Safety loop tucks up nicely. You would drag the exhaust off the car before you would scrape it.
Old 01-27-2010, 05:51 PM
lemons12's Avatar
Thanks for the input. As of now I am going to be ordering a Midwest as soon as I got a free couple of bucks.
Thanks everyone!
Old 01-27-2010, 06:26 PM
01ssreda4's Avatar
Thats what you get for not handwashing your car
Old 01-27-2010, 06:40 PM
lemons12's Avatar
Yea yea.... It was about 35 degrees and needed a spraying off.... **** THAT!
No way it would go through a auto car wash or that brush touch it, just a nice spraying off!
Old 02-23-2010, 05:40 PM
joblo1978's Avatar
I've got spohn's, no loss of clearance at all.
I got rid of the BMR for that reason.
Old 02-25-2010, 12:36 PM
ssvert99's Avatar
here is a pic of our bolt-on driveshaft loop. you can't get a better fitting loop that will work with almost any exhaust or torque arm, and does not hang low.
Old 02-25-2010, 05:08 PM
Giddswat's Avatar
My Midwest fits great, just make sure you move your fuel line like you see in Eric`s picture.
Old 02-26-2010, 10:44 AM
ssvert99's Avatar
^^^ true-dat if you want a little more simple install, but it is designed to be fitted between the fuel/brake line assy so they remain is stock location. works just fine either way.
Old 02-26-2010, 11:34 AM
01ssreda4's Avatar
Lemons what happened to your sig????
Old 02-26-2010, 12:01 PM
StealthFormula's Avatar
I recommend the MWC loop as pictured. I bought one last year and it works perfect with my TD's, you will lose absolutely no ground clearance whatsoever.
Quick Reply: Safety loop w/ lowered car
