weight of hollow 35mm front sway bar?
just picked up a 35mm front bar off of a bilstein ultra car. definitely feels lighter than my solid 35mm UMI, but it's double the weight of my stock 30mm bar.
anyone know the approximate weight of a hollow 35 or for sure if the bilstein firehawk cars got hollow or solid bars? one source online says hollow, the other says solid.
thanks
thanks
yeah it still weighs quite a bit but turns out it is actually hollow
info here:
http://www.firehawkowners.com/option...l/1835135.html
also confirmed by sam strano and others in posts i found while searching
info here:
LS1TECH Sponsor
so what does it weigh? I know what mine weighs, and it sounds like theirs is a lot heavier. My bar in a box (a big box 56x21x3") with all the endlinks and bushings and clamps is 20 pounds out the door. The bar itself is about 15 pounds which is about 3 pounds more than stock 32mm, about 5 more than a 30mm. If your bar is really double your stock bar... that's surprising for a hollow bar unless it's got a wall thickness that is just stupid thick.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
just reweighed them (bathroom scale):
30mm with mounts, bushings, and endlinks: 12lbs
35mm with mounts, bushings, and endlinks: 19.2 lbs
i thought the stock bar came out to 10lbs last time which is why i rounded to double. i guess either the scale isn't accurate or i wrote it down wrong.
