Drag Racing Tech
Took the T/A to the track, 1st time
Old 01-24-2010, 07:43 PM
sean1997ws6's Avatar
Default Took the T/A to the track, 1st time
I took my 01 WS6 to the track tonight for the first time with this car. I didnt know what to expect because it pretty close to stock. I had a 97 Ws6 M6 and could cut 2.0 60s all day but not with this one.
60ft-2.2028
330ft-5.78
1/8th-8.697
1/4-13.2710
Car has just magnaflow CB and lid with a filthy K&N. I think my clutch may be letting go because at the end of the track the peddle was very squishy until i shifted a few times. I guess I know where i need to go. I was consistant 13.3 all day and hit 108mph twice. Any advice for the lauch of an LS1? I would ride it out at about 2-2500.
Old 01-24-2010, 08:31 PM
Tscape16's Avatar
Originally Posted by sean1997ws6
60ft-2.2028
330ft-5.78
1/8th-8.697
1/4-13.2710
Looks like some pretty solid times to me if you factor in the 2.2 60ft vs a 2.0 you used to run. Are your tires any different? Anything can make a difference.
Old 01-24-2010, 08:59 PM
thunderstruck507's Avatar
those are pretty good times for stock, especially considering the shitty 60ft
Old 01-24-2010, 09:46 PM
JD_AMG's Avatar
60ft-2.2028
330ft-5.78
1/8th-8.697
1/4-13.2710
Search the manual transmission forum for your squishy pedal, it may not be the clutch going bad, it could be something as simple as needing to change the fluid. (or needing a better master cylinder, or a new slave cylinder).
Old 01-24-2010, 09:56 PM
sway99bird's Avatar
Not to bad
Old 01-24-2010, 10:41 PM
01 Trans-Am WS6's Avatar
Very good times for a pretty much stock car. When my car was exhaust/lid only best I ran was 13.4 and I have an 01 WS6 6 spd myself.
For the pedal feel you had look just read this link and it will give you all the info you need: https://ls1tech.com/forums/manual-tr...-write-up.html
Old 01-25-2010, 04:03 PM
The 2.0 was in my old LT1 car. I am on sumitumo tires. I was thinking if I could cut that down to a 2.0 I might see a 12.9. I was the slowest Fbody out there.
Old 01-25-2010, 05:04 PM
MattxFatal's Avatar
I wouuld say that's actually pretty good for a near stock car.
Get that sixty down just a little and bam, in the 12's.
Old 01-25-2010, 08:30 PM
Im getting LT Headers and LCAs soon so hopefully I should be solid in 12s
Old 01-26-2010, 10:43 AM
Juicy J's Avatar
What did it trap?
Old 01-26-2010, 10:59 AM
TooLateVTEC's Avatar
Where are you from?
That is a pretty respectable ET for a C/B and Lid/filter on street tires.
Good job.
Old 01-26-2010, 11:06 AM
chadaclysm's Avatar
I'd be very happy if I pulled a 13.2 my first time to the track lol. Congrats! Now find a zero traffic back road with a stop sign, and practice those launches.
Old 01-26-2010, 11:36 AM
01ssreda4's Avatar
I agree....
Old 01-26-2010, 07:18 PM
I trapped 108 on the 13.2 and trapped another 108 on a 13.3, but I was mostly running 107. Ordered my pace setter LTs and frost tune, wonder where i should be then.
Old 01-26-2010, 07:53 PM
chadaclysm's Avatar
Only one way to find out....
Old 01-26-2010, 07:55 PM
Yes in deed! im happy with the car. There were 3 SS camaros there running in mid 12's with headers and bolt ons. and 1 with cam running high 11s so a 13.2 was far from impressive to me that day.
Old 01-28-2010, 09:48 PM
99FormulaM6r's Avatar
Why can't there be people like you on Pass Time???? Every time I see a stock fbody i get sick with 13.7-13.9 quarters....damn
EDIT: Espcially with a stock '09 I think Mustang running a 14.09
Old 01-28-2010, 09:53 PM
I wish I was on a "stock" Pinks because I was so consistant with the 13.3s
Old 03-23-2010, 07:04 PM
Alright, Just put my Pacesetter LTs and offroad Y on this weekend and got my tune done my steve at Frost, Thinking I should be into high 12s now, What you guys think?
Old 03-23-2010, 07:15 PM
a few pics
Attached Thumbnails Took the T/A to the track, 1st time-sl380496.jpg   Took the T/A to the track, 1st time-sl380487.jpg
