5.3 starter
Old 01-26-2010, 11:34 AM
lamdenali's Avatar
Default 5.3 starter
anyone know if an LS1 starter will fit a 5.3 motor ? or any parts #
Old 01-26-2010, 11:49 AM
Gingervitis Addict
slow67's Avatar
Yes, I have an LS1 starter on my 5.3. And a 6.0 Flexplate for a 4L80 too.
Old 01-26-2010, 12:29 PM
lamdenali's Avatar
Thanks Bro
Old 01-26-2010, 05:47 PM
jomomma's Avatar
the only difference ive seen in ls startes is some starters have different bolt lengths than others.
Old 01-26-2010, 06:32 PM
Pocket's Avatar
Solenoid is clocked slightly different and the body length changes over the years, but for the most part they interchange with no fitment issues
Ill post up a few pics comparing a GTO starter to a LS1 Fbody starter later on
Old 01-26-2010, 10:48 PM
dynodanmanda79's Avatar
Please do post some pics of the GTO and LS1 F-Body starters, do you know if the LS1 F-Body starter will work with the GTO mn12 bellhousing?
Thanks, Dan
Old 01-27-2010, 11:01 AM
lamdenali's Avatar
I have an 6.0 with 4L80E and the starter is different then the LS1
Old 01-27-2010, 12:21 PM
the_merv's Avatar
^^X2..
I have a 1999 Sierra 5.3 and the LS1 car Starter will NOT work. There is a Casting Lug on the Block that is in the way.
Old 01-27-2010, 12:51 PM
Gingervitis Addict
slow67's Avatar
My 5.3 is an '04 I think and my starter is a 2000 LS1.
Old 01-27-2010, 01:48 PM
Pocket's Avatar
Fbody, GTO, similar length and solenoid size
Fbody, GTO, solenoid is clocked differently
Fbody, GTO, snout height is different. Both appear to cover the Fbody T56 flywheel the same
Fbody, GTO, bolt comparison
Fbody starter on my 5.3. No block interference
Fbody starter MAC mids clearance
GTO starter on my 5.3. Again, no interference
GTO starter MAC mids contact. Header flange isnt flush to the head with this starter
Ready to go!
Old 02-01-2010, 07:22 PM
Well I found out today that my 5.3 starter didn't work with the mn12 bellhousing. Has anyone else had this issue? I guess i'll buy the ls2 starter
Old 02-02-2010, 12:20 PM
fmowry's Avatar
'04 GTO starter was made by Mitsu did not bolt up to my LS6 w/T56 Bellhousing.
The 6.0 truck starter is a half inch shorter than the Delco f-body starter. But I think there are two different 6.0 truck starters. My shorter one came from an Escalade.
The bolts holding the housing together on some of the f-body replacement starters are longer than the OEM. One I got from Rockauto was that way. The Autozone was exactly the same length.
I went through all this crap trying to find a starter that cleared my Sanderson shorties I had to use in an LSX swap into a Miata. Ended up using the 6.0 Escalade starter.
Frank
Old 02-02-2010, 12:26 PM
530sx's Avatar
good thread I had no idea the starters had any difference between setups/years!
Old 02-04-2010, 05:42 PM
turbo370supra's Avatar
ok i have a 6.0l truck block. stock manifolds turned around, th400 trans and a tci flex plate. what one do i need
Old 02-04-2010, 07:54 PM
1A Dan's Avatar
interesting. looks like the Fbody starter's the best choice if you're running exhaust that's tight to the block.
Quick Reply: 5.3 starter
