Low beam OEM bulb $$$?
Cady dealership here quoted about $300 for the bulb alone, part only. This has to include the labor for the install or am I wrong.
probably not. But here is a much cheaper alternative to the stealership...
http://www.amazon.com/Sylvania-39663...ecc_rvi_cart_1
Failure rate of matsushita ballasts is 1 in 7,500...... You ever tried the lottery??
I agree one that. I am not sure if our cars come with matsushita but most stock hid cars do. If so a complete kit can be had for under $400 now days. Unless you have no mechanical skills at all, you should be able to swap the bulb.
