Machine shop in houston? (lt1 heads)
Old 01-27-2010, 01:06 PM
jasonz28camaro's Avatar
Default Machine shop in houston? (lt1 heads)
i am going to buy a custom grind cam to go with some afr 190cc heads. i need to find a good machine shop to tell me everything about the heads so i can give them to the cam man... they are assembled and have double springs so i guess i will need to know spring compression, flow #s and such. also im not too sure of everything that needs to be checked so if anyone has any recommendations i would appreciate it.
Old 01-27-2010, 01:52 PM
SiL3NtXWS6's Avatar
Talk to Bryan N. @ LME (late model engines)
Off beltway 8 @ clay and brittmoore.
Old 01-27-2010, 01:56 PM
cambirdracing's Avatar
Houston Engine and Balancing in Pasadena
Old 01-27-2010, 02:54 PM
gtorep's Avatar
USA Racing Engines over near Hobby Airport
Old 01-27-2010, 05:39 PM
sounds good ill check them out. thanks
Old 01-28-2010, 09:59 PM
mighty mex's Avatar
x2 for usa racing engines "wop shop" talk to bruce
Old 01-28-2010, 10:12 PM
T0rk's Avatar
In for USA also. They did the valve job and valve work on my 95 build.
