Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Would a LS T56 bolt to a BBC 502?
Old 01-27-2010, 08:42 PM
ranger2339's Avatar
Cool Would a LS T56 bolt to a BBC 502?
Ok so I'm selling my LS1 T56, LS2 flywheel and clutch on Ebay, I had a question regarding my trans,clutch and flywheel working on a 6th Gen BBC 502?
Would it work and if not why? I searched a little and read something about the LT T56 working because of the input shaft?
Thanks,
Josh
Old 01-28-2010, 04:46 AM
In-Zane Moderator
ZONES89RS's Avatar
Both will work:
The LS1 trans just needs a flywheel that will adapt it, dont know what flywheel but that is all it would need:
The LS1 trans will work with :
The adapter bellhousing and the pilot bearing sxtension.
The LS1 trans uses a plate that adapts and uses a T5 bellhousing so you can use whatever clutch and pressure plate you want as long as it is a 153 tooth wheel.
the LS1 might be easier to use but the LT1 trans might be near impossible to get a flywheel to work unless the stock LT1 style flywheel will bolt to it and be the same balance as the engine.
Old 01-28-2010, 07:45 AM
ranger2339's Avatar
Awesome! Thanks for the info. I will pass it on.
Thanks,
Josh
Old 02-02-2010, 11:02 AM
raped 95Z's Avatar
Theres a company in Mass. Called Fortes performance, that makes a kit. the Ls1 6 speeds will bolt up with adapters. ( you actually swap to an old school 4 speed Bell housing. if you use an Lt1 trans you need to replace the input shaft with the Ls1 input shaft ( its longer to make the reach when converting to a 4 speed bell housing...at that point you use your external balance flywheel and a clutch to match. hope that helps
Old 02-02-2010, 07:24 PM
e-racer-ls-1's Avatar
I just did the swap you are asking about.I have a 454 not a 502.I used my stock flywheel, a centerforce clutch set-up,a lakewood scattershield(only because I had it) and a adapter plate from "the gearbox".You do need a ls-1input shaft if using a lt trans.Pretty simple bolt together gig.You do need the longer pilot bushing.Hope that helps...
Old 02-03-2010, 10:27 AM
ulakovic22's Avatar
Not sure if you got your answer or not so I'll throw my .02 in.
LTx T56 will bolt up directly to any SBC/BBC as long as it's a one piece and the flywheel is balanced properly. You can bolt it up to a 2-piece, but you have to have 2-piece flywheel that will work with the LTx. McLeod, Findanza, Centerforce all make one.
I run a Gen V 502 block (1-piece), but it's been stroked and at the time only 2-piece 4.25 cranks were available so I have to use an adapter to adapt the crank to the block and a different flywheel to adapt the 2-piece crank to my LTx T56. If I was able to get a 1-piece 4.25 crank I could have just bolted everything up and saved some $$.
LSx T56 will bolt up but you need to use a different bellhousing because the bolt pattern and input shafts are different. Same flywheel issues as before.
Also remember that a LSx and LTx use different clutch hydraulics and function differently. LTx is a pull type clutch and LSx is a push so make sure you think of everything you need.
Old 02-03-2010, 11:30 AM
In-Zane Moderator
ZONES89RS's Avatar
Wel, technically the LS1 trans should bolt right up, it is the input shaft that is a different length.
Quick Reply: Would a LS T56 bolt to a BBC 502?
