Victor Jr or Super Victor in a F-body? Post up some pics installed
Like the title says.. I wanna see pics of both EFI and carburated setups with the Victor Jr or Super Victor intake. This style intake from what I have read is becoming more and more popular as an alternative to a FAST which IMO is severely overpriced!
I am seriously considering doing this, but won't really be able to make a decision until I see the setup.. I have heard that if you stay EFI the best way to go is with a 4150 throttle body rather than a elbow but I just don't know how well it will fit under my stock WS6 Hood. I am not opposed to cutting, as long as when it's all said and done it still looks the same on the outside.
This is 1Hawk's car but he had a good picture under the hood for ya to see.
Two things to get full advantage of victor jr.
1. use the 4150 TB
2. use a cam suited for the short runner of the victor jr with a tight lsa (~110)
1. use the 4150 TB
The following users liked this post:
Outlaw_Maro (08-06-2020)
I have some pics of my Vic Jr., Accufab 4150, Spectre Carb Hat and tube to the filter in the drag Racing section. Give a minute to find it and I will post the link.......
Forget the elbow. It has been proven in other posts that going from the elbow and 90mm TB to a 4150 4BBL is worth 50-60 rwhp.
Here is the thread with my pics:
https://ls1tech.com/forums/drag-raci...tock-hood.html
LS1Tech Sponsor
Yep it is a Jr. Would the Super not clear a WS6 hood?? I thought it was tall enough to make it work.....
I just need to put a decent size shaker scoop on there and run Cary's intake, and a 4500 TB .
I'm not arguing, but what makes the 4150 with a carb hat better than a throttle body with an elbow.. either way you still are making a 90* turn.. I assume the 4150 TB straightens out the airflow just before it enters the intake??
The hp gain was listed in the dyno section a few months ago. I don't know how much the carb hat restricts flow, it is pretty big on the inside with a 4" opening, but I do know that the elbows cram the airflow to the back of the plenum. Might not be a big difference if you don't have the cam for a single plane....
Tsc/98/TA (05-20-2020)
