my beefy 10 bolt build...(W/pix)
Old 01-28-2010, 01:37 PM
disturbthepeace's Avatar
Default my beefy 10 bolt build...(W/pix)
If you cant call it a beefy ten bolt, I'm sure you can classify it as some kind of meat product....
Parts list:
precision 3.73's
factory auburn with ARP ring hardware (ebay $275 w/30k)
USA alloy axles (net $160 shipped)
MAC rear cover (WS6 store $138)
Raytec solid crush sleeve ($22)
ARP cap stude kit (thunder racing $28)
ARP 3 1/2 wheel studs (net $65)
oil, additives, new pinion bearings, paint $130 est
these are all est prices i don't know exactly what I paid in shipping. Honestly I like to forget about how much I pay for performance parts...
First i pulled the whole POS. it was getting a little too noisy, and the diff sounded like I had a bag of rocks in the posi.
I always thought it lame that the factory didn't coat their rear ends with some kinda paint. mine had 80k on it and looked like ****.
It's a pretty good pattern for a set of used gears, I reused the new/used carrier bearing but switch to a new set of koyo on the pinion. The original timken front pinion bearing was toasted.9making my noise) set backlash to .008
set up with all the ARP goodies
when it came to installing the rear cover i ran into clearance problems between the cap studs and inside lip of the cover. Only toke a couple of minute to fix though.
As posted before the hardware that MAC provides is a 1/4in too short.(lame)
I used my drill press to fix this. using a 3/8 bit to center each bolt hole i lock down the cover in place. Then I would then switch to a 1/2 bit to to deepen the counter sinked bolt hole.
All done after hours of cleaning and building
I think wheel studs on a car just look sexy
All in all a great mod. going from a 3.23 to these 3.73's isn't a huge jump but enough to justify it. The car feels great and doest dog in forth anymore. the gears are dead silent until about 75mph. I can hear a slight howl but only if the windows are up, the cut out is closed, and the radio is off. but who drives like that anyway??
est total spent: $820ish not bad!
Joe
Old 01-28-2010, 02:47 PM
mikefirehawk0623's Avatar
hope it works out for you
Old 01-28-2010, 02:48 PM
01ssreda4's Avatar
Nice work
Old 01-28-2010, 03:00 PM
94TRANS's Avatar
nice, very similar to what i did with mine!
Old 01-28-2010, 03:20 PM
LS1_Sean's Avatar
smilar to what i did. except for the 4.10's and mosher axels and a stock torsen diff.
Old 01-28-2010, 03:32 PM
therobman's Avatar
nice but for an extra 500 you could have picked up a used 12 bolt
Old 01-28-2010, 03:44 PM
Jwright41's Avatar
Nice setup Let us know how it does when you put the pedal down.
Old 01-28-2010, 03:47 PM
myc4ltwon's Avatar
Nice man! looks a lot better painted!
Old 01-28-2010, 03:51 PM
bore.me's Avatar
Looks beauttiful! How did you get rid of the rust and what did you paint it with?
Old 01-28-2010, 05:08 PM
massls1guy's Avatar
Looks really good. That must have taken a long time to clean all that grime off before you painted it.
Old 01-28-2010, 05:58 PM
smokeum99ta's Avatar
Whats the bug run?????? VW's are my first love f-bodies second.
Old 01-28-2010, 08:58 PM
BlackNightmare's Avatar
Nice build and cleanup. To give it a little bit more strength you should have welded the axle tubes to the housing. It may not have helped any but couldn't hurt.
Old 01-28-2010, 09:24 PM
SuperSport01's Avatar
+1 on welded tubes. It helps from what ive seen.
Old 01-28-2010, 10:24 PM
02sleeperz28's Avatar
Damn I should not have invested money in a 9 inch I'm a dummy.
Old 01-29-2010, 12:41 AM
its best is a 11.39 on 18lbs. its a small motor less the 2L...
a little simple green soak, a wire brush, and a lot of quarters at the car wash is all it toke....
Old 01-29-2010, 01:38 AM
HWI
HWI's Avatar
How does it go anywhere with those skinny *** tires?
Old 01-29-2010, 05:37 AM
redtail2426's Avatar
i sure hope it holds up for you,its risky throwing any money into a 10 bolt
Old 01-29-2010, 06:32 AM
cambirdracing's Avatar
Not really on a torque arm set up. Only if the rotational load is outside the center section.
https://ls1tech.com/forums/gears-axl...ing-worth.html
Old 01-29-2010, 11:11 AM
i agree.. if it was a leaf spring car I would have...
I like to think of it as a calculated risk. At this point the weakest part of the setup is going to be case distortion witch would lead to pinion bearing failure. if this happens I wont hesitate to slap a new front bearing in it and call it a day. still cheaper then a $2500 9in. i know not as strong but still strong enough..
i run a 6in DOT slick, with 70% of the weight of the car in the rear it hooks well. best 60ft is 1.47, hanging the wheels for most of that
Old 01-29-2010, 11:56 AM
223HAWK's Avatar
I just did all that to mine..Dont put slicks on it or youll be lookin for a new rear..I should have just bought a rearend when mine broke the first time..
I bought the axle brace kit from LPW even..
fawkn 10bolts..
