10 Second Club - MPH for 10.9's
122-123 mph good enough to go 10.9's?:eyes:
lavoy
01-28-2010, 11:22 PM
im not going to say its cake to do but i do know that if you do get 10s on that low of a mph you are really getting the short times down big time.
Sofls1
01-28-2010, 11:25 PM
Yeah, its enough, just depends on your combo and how well you hook
paint it black vette
01-29-2010, 03:54 PM
:nod: did 10.974 at 123.66 in my vette. my friend rob has gone 10.9's at 122mph in his. 2 different combos that hook preety good. both in the high 1.4 sixties with these times and mph
chrs1313
01-29-2010, 04:17 PM
yup can be done did a 10.95 at 122mph and also when magnus broke into the 10s first with his SI car he was actually running 119.x...
slide rule says a 120mph is good enough...
Thanks guys. I hope I'll be able to hit it after some lightweight mods I have planned.
lemons12
01-29-2010, 08:08 PM
Yes it is... What is your 60' times?
The run in my sig was a 1.49 60ft. Check out the vid below.
lemons12
01-29-2010, 08:18 PM
You have the mph definitely.. A 1.45-1.47 will net you your 10.X pass easily. I would be more concentrated on the 60' than the mph.
RedsrtAk
01-30-2010, 09:18 PM
Very doable....my sig time was with a lazy ass 1.61 60ft.
TOSTO RACING
01-30-2010, 09:51 PM
definatley enough I've been 10.90 at 120 with a 1.46 60 foot
Kurtomac
01-31-2010, 07:36 PM
dang on my 10 second pass I did 128...I think the Z06 has much more left in it...was only on a 1.63 60ft
87silverbullet
01-31-2010, 08:38 PM
My buddy went 10.99 at 123.46 with a 1.43 60'
KH504
01-31-2010, 09:50 PM
I went 10.99 @ 120.7 with a 1.43 60'
LT1Formula007
02-01-2010, 11:51 PM
I'm with the other guys on this.... It's more common than you think. If you get just a little more weight out of the car or somehow get it to leave just right and drop that 60' it'll hit the magic #. :)
Although Me personally, I have gone 10.99 at 125.6 mph (I'm sure the mph was more so due to the gears- It pulls hard up top) I was leaving easy with the stock 10 bolt with 3.42's. Needless to say I footbraked it to an outstanding 1.659 60' :eyes: It has alot more left in it, But I need to do some suspension work first. And a 9 inch. lol
Good Luck on getting into the 10's your almost there. :chug:
chrs1313
02-02-2010, 06:45 AM
you can go .40s with that mph or even high 30s with a great 60ft
odarabla
02-03-2010, 06:48 AM
My first time in the 10's. I went 10.99@122 mph with a 1.49 60ft. My best motor pass so far has been a 10.90@123mph with a 1.47 60ft.
I guess it's just a matter of tweaking the suspension and getting the car to 60 foot better.
odarabla
02-03-2010, 07:07 AM
lol I did this on the stock suspension. I didn't order my suspension until a few months ago and it is still not on the car yet. :D
NastyC6
02-03-2010, 06:45 PM
4 years ago at pinks all out in the show i ran a 10.21 @ 129, so with that mph (122-123) you should be running a little better than a 10.9.....
lemons12
02-03-2010, 06:47 PM
6 speeds are going to mph better than a4s with the same ET, couple guys in here have forgot that I believe.
EMiNENT13
02-14-2010, 10:05 PM
First, get a new rear end, like the S60, then maybe you'll get there! Better get started, you're slacking big time, everyone is staged and ready and you're still at the pits!
WS6Power
02-15-2010, 08:54 AM
Yep, its doable. Sat. I ran a 10.87 at 122.43 mph. This is a full weight auto car with stock 3.23 gears and a 1.63 60 ft.
Thanks, Brian. I guess I better get movin'
WS6Power: What combo are you running with those nice times?
Intercooler2
02-15-2010, 01:50 PM
Yep, its doable. Sat. I ran a 10.87 at 122.43 mph. This is a full weight auto car with stock 3.23 gears and a 1.63 60 ft.Car weight? Your weight?
WS6Power
02-15-2010, 02:48 PM
Well I`ve never weighed the car but its a full weight WS6. I weight 200 lbs. and I guess the car weighs around 3500 lbs. Stock 3.23 gear, Vig. 3200 stall, TR 224 cam, TNT 200 shot, bolt ons, & tune. And the rest of the car is 100% stock. 10.87 at 122 mph on a low bottle. It should run around a 10.50 with 3.73 gears and a full bottle.
Overall good run. Get it to sixty foot better and your there:nod:
PINKYPINKY
02-15-2010, 05:24 PM
yeah it can be done... work on your short times..
StreetSilverado
02-15-2010, 07:24 PM
It's an LT1 10's are IMPOSSIBLE!
I lied, should be good for 10's just get some of that good weather and SHAZAMM
WS6 SRT-8
02-16-2010, 06:45 PM
I ran the time in my sig with a manual.
odarabla
02-20-2010, 06:08 AM
I ran the same time but with 3 less mph. You went 1.51 60ft and My car went 1.47 60ft. So his statement was right on par!
