Key FOB fixed, but coolant temp sensor went out at the same time
Ok, back when we had our cold snap, my key fob and tire pressure sensors went out. This was the first chance I had to sit down and go through the fuses and whatnot. In case yall were wondering, there are no fuses for either of the two systems...doh! I also reset the computer. That brought my key fob back, but now my coolant temp sensor only works for the first few seconds of the car being on. WTF! I guess I need to call someone with a Tech2 to see whats going on with my gauge cluster.
I REALLY hate driving around without knowing the temperature of the car. The only other car something like this has happened on was an 01 Firebird that I put a 160 degree thermostat in. The computer thinks there is something wrong and shuts down the temp sensor and kicks the fans on high and sets the SES. I programmed that code out. My V has a new stock thermostat and the car runs between 190-195 degrees.
Any ideas?
Any ideas?
Well this was done yesterday afternoon and I've done about 130 miles. Trips of 15, 15, 20, 40, and 40+ miles and it still doesnt work. I'll be putting a little over 100 miles on it tomorrow as well. I'll give you a call Sunday if it doesn't start working tomorrow.
Like everyone else, this car has been one tiny problem after another...but still 100% worth it because I miss having a fun car that I can/need to work on. I havent had a sports car in 3 years before I bought this. I only got to drive for everyone else at the track.
Its working again. Yesterday it was still out and I drove the car a couple of times, but this morning it worked. Now I just need to get my TPMS working again and I'll be all set...until next time..haha.
Don't mean to revive this uber dead thread, but I'm having a similar issue. I was cleaning up my ground contact under the hood strut, put everything back together, all was good for a good 20 min while driving, then mid drive the temp gauge dropped out and is no longer reading (digital and needle/mechanical). It will intermittently work (KOEO after sitting for 10-15 seconds w/key cycling) but after about 5-10 seconds of it coming back to life it will just drop out and stop reading coolant temperature. I'm figuring its not the physical thermistor (NTC) as it will read like stated above.
Any help/insight would be awesome. Prior to cleaning the ground contact everything was working just fine.
If by cleaning the ground you disconnected the battery for any length of time, it could just be resetting itself. If I remember right it took a few days and several hot/cold cycles before mine came back. I wouldn't panic just yet.
I had a set DTC fault for Coolant temp Sensor Out of Range, more then likely due to when i disconnected the battery. Was able to clear fault with my ETHOS at work. All good now.
That you knew about. Did you attempt to scan your vehicle when the issue arose?
Mine was a stored Pending DTC, never displayed a CEL Indicator Light, but upon scanning the vehicle there it was. Wasn't there prior to my little adventure in cleaning my grounds, not sure why physically caused it, but new that the Coolant temp sensor itself was still good because it ohm'd out ok, and I was seeing a proper voltage signal @ the connector, plus there was no physical check engine light which would be immediate had the coolant temp sensor took a ****. Either way, the problem was solved, and wanted to share what solved my issue to almost an identical situation.
No I hadn't scanned it at the time. My pcm was fubar'd/locked at the time..although I didn't find out until about six months after this original post. I tried to tune it after I did the cam and couldnt connect HP Tuners or EFI Live to it. It took Al from "Chips By Al" and an old copy of "Tuner CATS" to get into it and load a stock copy of the tune back on.
