Crate engine depot pan?
That pan will fit but is about 2 inches below your crossmember when installed.Check out the lhx pan from RetroLsx.More money for sure but not likely to be the first part to be destroyed when you bottom out. This pan was designed for added ground clearance on many gm vehicles and is similar to the H3 Hummer pan you are looking at
