abs reluctor???
They are re-useable/transferable.
Tap it off in a circular pattern,it'll only be moving/shifting slightly for every time you complete a seies of hammer taps around it.
to install it on the replacement differential,once it's sitting on the carrier in what appears to be a visual perfect alignment to be started to go on,I use bolts (3/8 fine thread,coarse thread would probably work too),flatwashers(some very large in outer diameter),and nuts to draw the ring onto the carrier.The bolts go thru the 10 ring gear mounting holes in the flange area and progressivily tighten the fasteners in a circular pattern.Just as tapping it off is a little at a time,installing it is also a little movement for every circular tightening sequence of those bolts.
