Drag Racing Tech
Need a sticky 16" tire.
Old 02-01-2010, 03:47 PM
Black 99 Bird's Avatar
Default Need a sticky 16" tire.
So what is everyone running on there 16" stock wheels at the track? Need somthing for my 6-speed. What kind of 60' foot times are you pulling? Thanks!
Old 02-01-2010, 04:10 PM
Ph.D. in HUBRIS
custm2500's Avatar
255/55r15
26-10.5-16
Both work and there are othersk. Stock wheel is a touch too skinnie but unless you are making killer power you will be just fine with any 10is" slick on the stock wheel.
Old 02-01-2010, 04:26 PM
Nitroused383's Avatar
I will be running the 26-10.5-16 M&H Cheater slick. From what I have read it performs great for a manual car. Its a bias-ply street legal drag tire.
Old 02-01-2010, 04:45 PM
studderin's Avatar
for a 28 DR I started getting high 1.5s on the 275 M&H DRs great street tire too. Im really happy with them, run them on the stock 16x8 Z28 rims 24/7
Old 02-01-2010, 05:32 PM
All I have seen in the cheater is a 26x11.5. I would think that would be too wide far an 8" rim?
Old 02-01-2010, 05:34 PM
Originally Posted by custm2500
255/55r15
26-10.5-16
I am running a 255/50 DR on the 16s now, just looking for more grip.
Old 02-01-2010, 05:35 PM
I'm looking for a 26" tire that will be track use only.
Old 02-01-2010, 05:37 PM
By the way, I should be around 405-415 RWHP.
Old 02-02-2010, 12:49 PM
blubyu02's Avatar
where are yall getting the m&h cheater slick from to fit on a stock fbody rim 16x8, i too need the bias ply
Old 02-02-2010, 02:00 PM
bufmatmuslepants's Avatar
Sumikomo HRZs 245/45/16s FTW! 1.999 60' best, consistent 2.01x.
Old 02-02-2010, 02:04 PM
I read some other threads on here that the 26-11.5-16" cheater slick will fit on the stock 16x8 rim.
Old 02-02-2010, 07:58 PM
Hard Core Z28's Avatar
Go with a bias ply tire over a drag radial for a 6pd. You need the soft side wall to take some of shock.
Old 02-03-2010, 06:00 PM
Sooooooooo... Which one? Thanks guys!
Old 02-03-2010, 07:10 PM
TTA850's Avatar
On my 89 GTA I run a 28x11.5x16 Hoosier QTP DOT on on stock 16x8 wheels, it's been 1.47 60ft off a brake at 3650lbs and they are very consistant. I used to run the M/T ET Street 26x11.5x16 when I had a different gearset out back and had good results too, with 60fts in the 1.48-1.49 range, but they were not as consistant as the Hoosiers.
Couple of pics with the 28x11.5x16's out back
http://www.fquick.com/garages/viewga...ewimg&id=27081
http://www.fquick.com/garages/viewga...ewimg&id=27082
Old 02-03-2010, 07:18 PM
Hooiser quick time pros work great/
Quick Reply: Need a sticky 16" tire.
