Generation IV Internal Engine - Introducing the Ultra Track Attack LS7 - 717hp for the hardcore track enthusiast
Katech_Jason
02-01-2010, 03:51 PM
This is a new engine package we put together for the hardcore track enthusiast. The beauty of it is that it runs on $2.30/gallon, 105 octane pump gas E85. Over 700hp from 5900rpm and up, over 600 ft-lbs everywhere. Specs are below
http://www.katechengines.com/street_performance/images/engine_packages/Ultra%20Track%20Attack%20LS7_low%20res.jpg
Bore: 4.205
Stroke: 4.250
Displacement: 472ci
High hp version: 717hp @ 6500rpm, 632 ft-lbs @ 5500rpm
High tq version: 680hp @ 6100rpm, 650 ft-lbs @ 4600rpm
Compression ratio: 13:1
Fuel: E85
Redline: 7000rpm
Weight: 380lbs as pictured
Block: Dart/Katech billet, linerless with nikasil coated bores, billet steel main caps
Crank: Callies forged steel
Rods: Callies forged steel
Pistons: Katech forged aluminum
Heads: LS7
Valves: LS7
Intake: FAST 102mm w/NW 102mm TB
Camshaft: 2 choices available
Lifters: GM racing, hydraulic roller
Oiling system: ARE 3 Stage external scavenge pump, Katech internal pressure pump
Dyno graphs of the 2 camshaft choices
http://www.katechengines.com/street_performance/images/engine_packages/C2-8724%20&%20C2-8745.jpg
ringram
02-01-2010, 04:04 PM
Interesting spec with the nicasil bores.
What durability testing has been done on this?
There have been problems with nicasil bores on Jaguars and BMW engines before and Jag went back to steel liners.
Im guessing this is a track engine built for performance and not a street engine built for durability? Or am I guessing wrong?
DBN
02-01-2010, 04:18 PM
And the price is?
Katech_Jason
02-01-2010, 05:32 PM
We've ran 30 hour durability on the dyno and won Le Mans 6 times with similar bores. This block has been running for 2 years in C6RSs including track testing at Spring Mountain.
Right, it's built for track use, not street.
Katech_Jason
02-01-2010, 05:34 PM
And the price is?
Enough to start a war on this forum.
deelong4002
02-01-2010, 05:45 PM
I guess $30,000
venom ws7
02-01-2010, 05:49 PM
:eek:
I really wanna know!!!!
the engine and numbers looks beautiful..
How much do you think C6 ZO6 will dyno with right headers and tune??
Katech_Jason
02-01-2010, 06:01 PM
I guess $30,000
in parts
edit: more than that for parts actually.
MeentSS02
02-01-2010, 06:08 PM
That's some high dollar shit right there...very cool stuff. I wish I had the cash flow to roll something like that under my car. Guess I'll just have to settle for your valve covers and belt tensioner instead :(
Pwebbz28
02-01-2010, 07:21 PM
ALOT of $$$ FOR ONLY 700HP!! Sure is pretty though :)
LSX67RS/SS
02-01-2010, 08:12 PM
And the price is?
if you have to ask, then you can't afford:)
Katech_Jason
02-01-2010, 08:26 PM
Now that I think about it, we could have just bought a stock LS3 and slapped a Procharger on it. You're right.
Maybe we could do that for the C6.R too. Those cost $130k each and have only 580hp. I'll bring it up in the next staff meeting. Thanks.
MeentSS02
02-01-2010, 08:30 PM
If you guys decide to make the change to Prochargers with the Corvette racing program, I'll gladly buy one of the used engines you take out :jest:
Katech_Jason
02-01-2010, 08:34 PM
Ok, I'll set one aside for you.
MeentSS02
02-01-2010, 08:40 PM
Forgive me if I don't hold my breath...
Let the internet haters hate. You guys make top quality stuff - you've proven that to me with the belt tensioner and the valve covers and coil relocation kit...I can only imagine what an entire engine would be like.
helicoil
02-01-2010, 09:44 PM
LOL.
Wow only 380#, didn't realize a complete was so light.
Very nice engine!!
kumar75150
02-01-2010, 10:28 PM
:rotflmao:
kumar75150
02-01-2010, 10:29 PM
I guess $41,000
Pwebbz28
02-01-2010, 11:25 PM
Just so we are all clear this is wheel power or crank?
Wasnt hating in any way just said it was alot of money.
Im sure hoping its wheel power. If so its even more badass, but still alot of money :)
kumar75150
02-02-2010, 02:33 AM
It's from an engine dyno, not whp.
You have to understand who Katech builds engines for. These things have to last hours of continuous torture at high RPMs.
Pwebbz28
02-02-2010, 02:45 AM
So 472ci, 13:1 compression, $30k and only 717 at the crank? I would expect over 800 for the investment. I understand technology isn't cheap which is what this motor is chocked full of. Nikasil has been use fir quite some time in jetskis and is awesome and $$$.
Ready to come play with your HPP 500ci Vette with my gimpy 408 T/A this spring :-)
Katech_Jason
02-02-2010, 07:52 AM
Money doesn't change the laws of physics. Hydraulic roller, stock head castings, stock valve size, and conventional intake manifold, these are the limitations.
kumar75150
02-02-2010, 06:17 PM
You know where to find me...and I'll be in the Ford.
Bink
02-02-2010, 10:37 PM
Do the math on the parts. :D
Top-notch and purpose-built by the Best. How many engine builders have won Lemans multiple times...much less with an LS based engine.
Katech is the Gold Standard.
Pwebbz28
02-02-2010, 11:19 PM
Not skeered :) 2nd stage will def be needed to keep up though :)
The Alchemist
02-06-2010, 07:39 AM
Very nice.
super6ute
02-06-2010, 09:00 AM
Is Dart doing 6 head bolt per cyl Billet blocks yet?
As your targeting the racer/weekend warrier why not go solid cam and employ better heads ect.
If I were outlaying this much, proportionly it wouldn't cost a lot more money?
I guess you make to order also?
Just wondering. Cheers.
Wnts2Go10O
02-06-2010, 11:07 PM
thats impressive jason. question though, why, on most "sbc" engines including the ls platform, do they have that strange dip in torque in the middle of the rpm range?
what some of you complaining seem to not realize, is that your piddly stock LS motor would explode with about 1/4 of the abuse Katech's engines are built to take. nicasil = not cheap, the machining and blueprinting time = not cheap, parts = not cheap. if you think you can build a multi-championship winning LeManns engine and then transfer that technology to the "civilian" market, no one is stopping you.
Pwebbz28
02-07-2010, 01:03 AM
My piddly stock Ls motor made 750 with 60 less cubes and im willing to bet it will withstand quite a bit of abuse.
Daryn
02-07-2010, 04:40 AM
katech is a very well known, im sure they will stand behind thier engines with a nice WARRANTY for 40k....... a reputable shop installs them or they install them and set the tune
The Alchemist
02-07-2010, 07:37 AM
There is a big difference between a drag motor and a road race motor. Consider that in a weekend of road racing, you're logging more engine rpms than a drag motor sees in an entire season, I can understand the difference in build materials and cost.
If I wanted a motor that would last an entire season of road racing, this would be the motor to get. Quite impressive.
daniel6718
02-07-2010, 08:35 PM
so a drag race version of this would cost what? ballpark?
zman1969
02-08-2010, 09:17 AM
is that with Hydraulic roller, stock head castings, stock valve size, and conventional intake manifold, these are the limitations?? I would think not, if they are I'm sure you'ld beat them at Lemans :D
Robin L
02-08-2010, 10:16 AM
OK it's a bet. Lets see how long your piddly stock LS engine holds up.
I would be willing to bet it's a dyno queen that has never had a REAL test of the durability.
You know, like a few laps.
Prove me wrong....:eyes:
Got to love the internet... sheesh
Robin
Katech_Jason
02-08-2010, 10:32 AM
It's related to intake/exhaust runner/primary length tuning.
Robin
I'll host the dyno shootout. How about 30 hours of durability? (if necessary)
Side note - we durability tested our forged pistons for 422 hours of WOT.
MeentSS02
02-08-2010, 07:43 PM
Pfffft...I drive 422 hours each way to work, uphill, WOT. ;)
Wnts2Go10O
02-09-2010, 01:48 PM
<snip>
oh, ok. i guess theres a "resonance" of sorts that the runners/primaries cause
MadIceV8
02-09-2010, 03:15 PM
This would be a monster on a road racing course with reliability to boot. It would be scary to come out of a corner and pull the entire way into the next.
MikeZ06402
02-11-2010, 04:24 PM
I agree there is a vast difference btween drag racing and roadracing engines in the terms of sustained durability. I built my car to run the TTU class with NASA (which is 1/100th the hours a Katech motor sees) and it still cost me well over $20K but I insisted on installing forged internals, Katech mains, Katech wiring adapters, Katech tensioner and had the rotating assembly balanced and heads flow tested by LBP out of Cibolo, TX. The motor has held for two seasons and counting. Was it worth it; hell yeah. If I had the money this motor would definately be in my car for the next season. Now if only I could find brakes as well engineered.
sr71bbjr
02-11-2010, 05:55 PM
:rotflmao::rotflmao::rotflmao::rotflmao::rotflmao: :rotflmao::rotflmao:
