After 180 amp alternator pcm acting funny.
Old 02-01-2010, 05:41 PM
Blk_Ws6's Avatar
Default After 180 amp alternator pcm acting funny.
Hey fellas after driving for a lil while my dash lights up as if I just started the car ,I'm thinking its the alternator I had on here (180)amp ,and the car is now jerking when I eased on the gas what do you think is going on?
Old 02-01-2010, 06:18 PM
Kleeborp the Moderator™
MeentSS02's Avatar
You HAD the alternator on there, or still do?
If you still have it on there, are you getting a full charge at idle (look at your voltmeter for a rough idea)? Higher amp alternators are notorious for having a higher set point RPM-wise to get a full charge going, and the issue is even worse if you are running an underdrive pulley. Unfortunately, I don't know any other details...
Beyond that, the alternator shouldn't be causing problems like that unless it is flat out just going out. When mine died, the car didn't run very well at all.
Old 02-01-2010, 06:42 PM
Blk_Ws6's Avatar
yes i had a 180 took it off, And yes i have a underdrive pulley.
Old 02-01-2010, 06:56 PM
MeentSS02's Avatar
Auto or manual transmission?
Old 02-01-2010, 06:58 PM
MeentSS02's Avatar
Well...if it isn't on there now, it shouldn't be an issue at all. Did you damage the small wire that plugs into the top of the alternator while you were messing with it?
Old 02-01-2010, 07:36 PM
Blk_Ws6's Avatar
yeap it was cut had to tape it back. Auto ls6 conversion.
Blk_Ws6's Avatar
I think the jerking comes from him not using new gaskets on the intake.
Old 02-02-2010, 11:02 AM
MeentSS02's Avatar
New intake manifold gaskets? Doubtful...it really isn't all that necessary to replace those every time you have it off. You might have a vacuum leak elsewhere though if you didn't hook everything back up properly - there are quite a few vacuum connections in the back. You might also make sure that the brake booster line doesn't have a hole in it or something...
Old 02-03-2010, 06:02 PM
Blk_Ws6's Avatar
I have some small lines that's not connected ,but he says its from the Air conditioning.
