Sponsor Group Purchases - PST 93-02 F-Body 3.5" aluminum driveshaft GP
LS1 SPEED
02-02-2010, 10:03 AM
GP will be 93-02 F-body shafts and require a min of 10 orders..well 9 since I count as 1 ;)
The GP will start today and run through Feb 12th.
http://www.pstds.com/Images/aluminium_driveshaft.jpg
Street - Strip Aluminum Driveshafts.
6061-T6 Dom tubing gives the most concentric Aluminum Driveshaft available. High strength aluminum tube yokes are Mig welded with less than 10 thousands total run out. The aluminum driveshaft is electronically balanced to less than 1/4 oz/in to assure vibration free operation.
-Highly polished
-3 1/2 diameter / 120 wall alum.
-cryo treated slip yoke and u-joints
-track tested to 1200 HP
-shafts weigh approx 14#'s
These shafts are made to be direct fit for most popular applications. stock rear , 12 bolt, 9" , S60. They all come with the 1350 rear yoke, so if going to a stock 10 bolt a conversion U-Joint would be needed Napa P/N 447.
custom length available as well with proper measurements provides
The direct replacement shafts will be $399.99 shipped within the Cont. US.
The custom length shafts will be $420 shipped within the Cont. US
custom shaft measuring info:
http://www.pstds.com/Images/driveshaft_measure.gif
use measurement X
please call to place your order since we have not yet added these to our site
866-571-SPEED
Sofls1
02-02-2010, 10:10 AM
Larry,
If I placed my order today, how long would it be til I received it?
LS1 SPEED
02-02-2010, 10:20 AM
We need to meet the 10 and they should ship within 2 days from that time.
Grifter
02-02-2010, 12:33 PM
I'm in.
johnzss
02-02-2010, 01:32 PM
im in!
02sleeperz28
02-02-2010, 01:34 PM
Hmmm maybe I'm thinking....Order chromoly one from Strange like Larry told me awhile back for my old car or get in on this sale for my 9inch???
LS1 SPEED
02-02-2010, 01:35 PM
Can this work on a 9inch with a full spool? Stock lenght?
it will be fine and PST has all lengths covered per setup
please call to place order which will confirm that we move forward with this GP
02sleeperz28
02-02-2010, 01:38 PM
I edited my post check out above comment. Still thinking?
LS1 SPEED
02-02-2010, 01:44 PM
I'm changing to try and save weight anywhere in the driveline. This will be about 4-5#'s lighter then the CM. I also took 10# off my crank by a pulley swap and converter change. These little things all add up for HP in the end :)
gjohnsonws6
02-02-2010, 02:30 PM
Thank you for setting this up I have a ? tho.. Are the u joints solid or greaseable?
LS1 SPEED
02-02-2010, 02:45 PM
glad to help with the GP and offer a great product
u-joint info
1350 Spicer Series: Manufactured with OEM tolerances and treated with our Cryogenic Process to yeild the strongest U-Joint available. For drag racing applications a solid non-lube design U-Joint is recommended because of the tremendous initial shock load, or short duration of high torque the joint must be able to withstand.
Grifter
02-02-2010, 03:48 PM
I'm going to give you guys a call tomorrow to place my order. Is there a best time to call?
Thanks again for setting up this GP.
LS1 SPEED
02-02-2010, 03:49 PM
Sales is open 9a.m to 8 p.m tomorrow ( closed 4:30-5:30 )
glad to help
flyinZ
02-02-2010, 07:10 PM
Im in. Off the top of your head, Larry, whats the length of a DS, for an M6/S60 rear setup? If not, I'll have to wait till weekend, to measure ;)
Thanks for the GP
LS1 SPEED
02-02-2010, 07:32 PM
Thanks for the GP
I have notes at the shop and PST has us covered on the regular swaps as noted.
talk to you soon
Lucifer 00
02-02-2010, 07:41 PM
I'm in,
Larry, I also need a drive shaft for an M6 and S60, let me know if there is a common measurement because I haven't installed my rear end yet!
LS1 SPEED
02-02-2010, 08:06 PM
I will be able to handle the details for the proper length, so no worries.
CAMARO_THUNDER
02-02-2010, 11:43 PM
Thanks for doing this guys! I'm in for a custom length since EPP won't answer the phone anymore.
01wssick
02-02-2010, 11:54 PM
Looks tempting, hmmm is this a direct fitment to a 10bolt/4l60e (2001).
Whats the benifit of it over a stock driveshaft?
johnzss
02-03-2010, 12:48 AM
Larry,
I sent you an email in regards to my set up along with some pictures. i'll touch bases with you tomorrow. thanks!
LS1 SPEED
02-03-2010, 06:46 AM
stronger and it would require a conversion u-joint as mentioned since the 10 bolt has a smaller/weaker yoke
no problem... sales here are available 9a.m-8p.m tomorrow
Larry,
9" w/ 6 speed is handled under the direct replacement price
talk to you soon
LS1 SPEED
02-04-2010, 11:24 AM
We have 3 confirmed orders so far and 1 of those 3 being myself and 1 I sold for an install.
get your orders in by tomorrow and I will place those orders Monday. I will add to the GP as needed as orders come through until the 12th
This will allow people to get them a bit sooner as they will ship in 1-2 days of PST getting the orders.
CAMARO_THUNDER
02-04-2010, 03:08 PM
"By" as in before tomorrow or before the end of the day Friday ?
LS1 SPEED
02-04-2010, 03:11 PM
calling PST Monday to get the run of orders in which we receive by days end Friday Feb 5th
2nd run after GP ends Feb 12th
I'm just hoping the 10 come in by next Friday which I based this off. I'm doing this since it seems like some would like to get the DS sooner and I'm always all about helping.
CAMARO_THUNDER
02-04-2010, 03:54 PM
THANKS Larry!
I will place my order tomorrow then.
LS1 SPEED
02-04-2010, 03:55 PM
no problem
johnzss
02-04-2010, 05:28 PM
Just placed the order for the umi TA aswell via phone. thanks again! i'll be back for the SJM stuff
SLOWWZ28
02-04-2010, 07:33 PM
I sent an e-mail to get back to me when the required 10 orderes were in so I could officialy place the order and got no responce yet! Its hard to find time in the day to place a phone order! I ussualy order from your site at night. Let me know what I have to do to ensure my order is in.
Thanks, Travis.
LS1 SPEED
02-04-2010, 08:57 PM
thanks John
Thanks, Travis.
Travis
I'm confident the 10 min will be met, so when you get a second give our sales team a call. We are also at the shop Sat. from 9 - 12.
CAMARO_THUNDER
02-05-2010, 04:18 PM
Ordered mine today, cant wait to get my car back on the road.
Thanks again
LS1 SPEED
02-05-2010, 05:35 PM
no problem and thanks for the order
6 total orders counting my own at this time
flyinZ
02-05-2010, 05:38 PM
Ordered mine today too. :)
LS1 SPEED
02-06-2010, 10:35 AM
thanks
7 orders as of today
CAMARO_THUNDER
02-06-2010, 08:36 PM
Did you try posting this in the "GEARS & AXLE" section ? I'm sure it would help.
LS1 SPEED
02-07-2010, 08:06 AM
I did not since posting sales in other section besides sales is like walking on glass here. I just wanted to stay out of trouble with the site though all us sponsors make this site operate.
edit: I added it so I will see if I did it correctly to not get in trouble or the thread locked.
LS1 SPEED
02-08-2010, 07:02 AM
Monday bump
I have the 7 orders in with PST in and they should ship within a couple days.
GP ends Friday so please call or email to place your orders so we get to that 10
thanks
Grifter
02-08-2010, 08:54 AM
Monday bump
thanks
So what happens if the 10 isn't met?
LS1 SPEED
02-08-2010, 08:58 AM
it leaves little to no profit for us :(
Grifter
02-08-2010, 09:21 AM
Ah lame. Let's hope you can get 3 more!
LS1 SPEED
02-08-2010, 09:38 AM
I think it will work out and I did the early orders since some seemed to need their driveshafts sooner.
PAGregSS
02-08-2010, 11:20 AM
Larry, I have an M6 with a Moser 12 bolt. My LPE 3.5" driveshaft is stock length, but it's too long for the 12 bolt. It's so tight, I can barely get it out of the rear yoke when removing it. I believe this will require a custom length, but which pricing structure would this fall under?
I'm pretty much in for the GP either way. I was intending to order a PST shaft shortly anyway.
LS1 SPEED
02-08-2010, 11:23 AM
They have bolt-in shafts for 4L60E/T56 to 12 bolt, S60 and 9".
The price will be $399.99
PAGregSS
02-08-2010, 11:38 AM
Ok, just to confirm. The fitment they have for the M6/12 bolt is shorter than stock, correct? That's my biggest concern.
LS1 SPEED
02-08-2010, 11:48 AM
PST is 1/8" shorter for a 12 bolt v's their 10 bolt shaft.
44 1/4 v's 44 3/8
We are not sure what the LPE shaft measures at, but we can assure you the shaft will fit properly.
4bangermustang
02-09-2010, 05:19 PM
Does it have to be aluminum?
LS1 SPEED
02-09-2010, 05:24 PM
technically yes, but email me and maybe I can still help you out
Grifter
02-10-2010, 08:10 AM
Any update on the ones that have been ordered? Did any ship out yet?
LS1 SPEED
02-10-2010, 08:24 AM
yes.. I had them shipped direct and went out Monday.
no tracking #'s though, so just look for them by the end of the week
Grifter
02-10-2010, 12:31 PM
Awesome, thanks for the update!
Sofls1
02-11-2010, 12:34 AM
I'm in! Will call sales in the morning to place the order! Nothing like waiting til the last minute. Just out of curiosity why are the 4l60e to 12 bolt shafts 1/8" shorter?
LS1 SPEED
02-11-2010, 06:44 AM
Sof..you will be #10
sorry no prizes :)
Lucifer 00
02-11-2010, 09:38 AM
Just ordered mine, whats the expected shipped date?
LS1 SPEED
02-11-2010, 09:42 AM
thanks.. I will try to get everyones orders from this week out by Monday Feb 15th.
Sofls1
02-11-2010, 10:08 AM
Order placed! Always a pleasure dealing with you guys!
LS1 SPEED
02-11-2010, 10:16 AM
thanks Steve
flyinZ
02-11-2010, 05:09 PM
Got mine today! :) Thanks!
LS1 SPEED
02-11-2010, 05:10 PM
me too!
Grifter
02-11-2010, 08:35 PM
Didn't go into work today, hoping to see it tomorrow morning.
Glad to hear we got 10!
LS1 SPEED
02-11-2010, 08:51 PM
us too!
PAGregSS
02-12-2010, 06:53 AM
I was on the fence as to whether I wanted to order a custom length or go with the direct replacement. With our snowstorm here on the east coast, I didn't get a chance to get under the car and measure this week, so I guess I'll call today and order the direct since you assure me it will fit correctly.
LS1 SPEED
02-12-2010, 06:59 AM
PST told me they have it covered, it can never hurt to check.
I can give you until first thing Monday to be sure if that helps.
Grifter
02-12-2010, 07:22 AM
How were they shipped; UPS or Fedex?
LS1 SPEED
02-12-2010, 07:23 AM
They were shipped via UPS.
Grifter
02-12-2010, 07:48 AM
Thanks. We haven't gotten any shipments due to the storm so I just want to know what to look for.
LS1 SPEED
02-12-2010, 07:56 AM
cool....
CAMARO_THUNDER
02-12-2010, 11:22 AM
Got mine yesterday also... Thanks again and TTT for you!:D
johnzss
02-12-2010, 01:55 PM
Any word on mine? Its friday afternoon here in CA.. maybe by end of today?
LS1 SPEED
02-12-2010, 02:01 PM
just give it some time.. anything before next the end of next week is ahead of schedule :)
PAGregSS
02-12-2010, 05:12 PM
Thank you, Larry. That is much appreciated. I will get the car up in the air tomorrow morning and measure. If folks will be in tomorrow, I'll give a call with my order. I'd rather measure and be sure to get the right thing. Especially since I already have a $500 shaft that doesn't fit right.
Grifter
02-12-2010, 06:13 PM
Got mine today! It was sent to my house though but no worries.
Thanks again.
LS1 SPEED
02-12-2010, 06:52 PM
no problem
Thanks again.
cool
johnzss
02-12-2010, 11:36 PM
The T/A from UMI came in today, thank you! hopefully the drive shaft will come tomorrow? i believe i was 3rd to place an order. thanks again!
LS1 SPEED
02-13-2010, 07:18 AM
it will most likely be Monday since UPS normally doesn't deliver Saturdays
UMI is less shipping time then PST since they are in FL
PAGregSS
02-15-2010, 07:24 AM
Got it measured yesterday. Larry, is the shop open today? I keep calling but it appears the phones are turned off.
LS1 SPEED
02-15-2010, 07:44 PM
The shop is open Mon,Tue,Thu, FRi 9-5 central time and Wed 9-8. I was in the shop from 7:15-11a.m today and had to leave for the afternoon.
if you did not get in touch with someone please call me tomorrow between 9 and 5 ( 11:30-12:30 closed for lunch )
thanks
johnzss
02-15-2010, 08:21 PM
Came in today. cant wait to install it tomorrow! thanks!
LS1 SPEED
02-15-2010, 08:22 PM
cool.. they sure look pretty don't they:nod:
PAGregSS
02-16-2010, 06:48 AM
thanks
Ok, I'll try again today. I called from 9 a.m. eastern time all the way up to about 1:30 p.m. eastern time and everytime I called I just got a busy signal.
LS1 SPEED
02-16-2010, 06:59 AM
sorry about that, but sometimes it gets that busy to where we can not even makes needed calls to order things
I will say Monday tends to be the busiest day and hope you have better luck today.
johnzss
02-16-2010, 04:32 PM
Larry,
Sent you a email regarding my T/a.
LS1 SPEED
02-16-2010, 04:34 PM
Larry,
I do not have my PM's on, so please email me.
Franklin
02-17-2010, 04:41 PM
Is this still going on?
thedudeZ
02-17-2010, 06:35 PM
I think we might be too late. I'd like one too.
LS1 SPEED
02-17-2010, 06:36 PM
never hurts to give us a ring as we always like to help :)
thedudeZ
02-17-2010, 06:41 PM
tried to call today. mind pmng me a price for custom length th400-9in with slip yoke?
LS1 SPEED
02-17-2010, 06:57 PM
sorry if you could not get through by phone earlier today
I do not use PM's so you can email or call me now if you would like.
x 116
thedudeZ
02-17-2010, 07:04 PM
want me to leave a message or call back?
LS1 SPEED
02-17-2010, 07:06 PM
I'm sitting at my desk and if you happen to call and I am on another line yes leave a message with a phone # to reach you at.
thedudeZ
02-19-2010, 06:45 PM
Ordered mine today. Thanks Larry for your help.
