Ford to Chevy driveshaft
Ive never screwed with transmissions and drive shafts before, but if i go to a 4L60e, and keep my ford 8.8 rear, other than shorten/lengthen the driveshaft, what do i need to do? Will the yoke fit the transmission ok?
OK so what all will i need? I got a brand new steel drive shaft and u joints recently that's why im asking. I know i will have to have it modified in length most defiantly. But will my yoke go into the 4l60/65? Or will that need to be changed too? I got a donor corvette with parts so i can take that one if i need too. Just trying to get all my parts before i do my swap, need as little downtime as possible in the vehicle.
Ok so im still confused on what all im going to need to do and parts im going to need. Trying to get all this together before tearing into the truck. Need as little downtime as possible in my swap.
I "think" the stock driveshaft slip yoke for a A4 f-body is 27 spline. I know the T56 uses a 27 spline slip yoke and I am pretty sure the auto uses the same. If that is the case, you can order a slip yoke from Moser for about $90 that is setup for a 1350 u-joint. Hope this helps.
