Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Philadelphia, I can use some help.
Old 02-03-2010, 03:02 PM
OutToWinPAHC's Avatar
Default Philadelphia, I can use some help.
I am trying to get my T56 in and its just too tight on my 240sx. I removed a TH350 and I am swapping it to manual trans. Anyhow I am posting on the forums for a little help. I only have 2 options, cut the floor open which requires removing a rollcage, dash, seats and carpet ( dont like this option) , or lowering the engine/ crossmember down and inch or twp and mate them and then jack them in place.
I am trying to find an engine lift, the ram on mine is missing, but no luck yet. So if your interested in helping me work on my Spec sponsored LS/T56 Nissan 240sx and have an engine crane and maybe a tall floor jack please let me know.
Yuingling is on tap, and Chickies and petes is up the block, dinner on me
Old 02-03-2010, 03:43 PM
98TA_vert's Avatar
if you go to a NAPA and get somebody that knows there **** they sell the rams for the engine lifts
Old 02-03-2010, 03:48 PM
I can buy a ram, they are about 100 bucks, I just dont want to spend a extra hundred, I rather ask for help and treat to some food and beer. Plus offer my help in return some day. I believe in helping others/.
Old 02-03-2010, 07:50 PM
Got a buddy dropping off a crane tommorow, finally this trans will be in, from TH350 to T56, it should be fun.
Old 02-03-2010, 07:55 PM
mikep2002's Avatar
Any trashy women around????
Old 02-03-2010, 07:56 PM
DiabloFormula's Avatar
Only you if you come in drag.
Old 02-03-2010, 08:23 PM
Your local sleeper. Checking in 600-800lbs less then a normal LS1/6 car
Old 02-03-2010, 09:38 PM
nerisls1z's Avatar
sweet ride if I would have been on earlier you could have borrowed one of mine got 2...hope everything works out
Old 02-03-2010, 11:50 PM
stealth355tpi's Avatar
down by the river where everyone hangs out? good luck with the swap, if got a buddy doing the samething in a s14. any pointers?
Old 02-04-2010, 05:14 AM
Mine has been in for 3 years so this isn't a swap kit. If he uses a kit I suggest daft innovations. Rich makes nice stuff and he sold me all my T56 stuff (lines, remote bleed, CMC and braket, and even the T56 crossmember. His headers are also very nice for the money.
Old 02-04-2010, 05:15 AM
I would use the hinson radiator too, with an electric water pump
Old 02-04-2010, 07:42 AM
TNTramair's Avatar
sweet ride....hope to see it around sometime. you go down to linden ave often with it?
Old 02-04-2010, 08:40 PM
took 3 hours and some snags but my LS1 is now officially married to a T56
Old 02-04-2010, 09:32 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Nice setup.
