Fox Body or F-Body
Fox Body or F-Body
If you had a choice to build an N/A LSX drag car... would you choose the f-body 98-02 or mustang fox body 87-93.
the goal is to get 8.6-8.9 N/A with 3000LBS and 750whp LS-series engine through a TH400 5500 Stall Speed.
do you guys seeing 8 sec possible?
say with a 1.25-1.30 60ft, 5500 stall speed, 4.10 gears with spool, 27X10.5 slicks, 7600 RPM, 3000lbs weight and 750whp 433i engine?
I think it would be pretty hard to get that much horsepower out of it w/o any power adder. With that said I dont see it running in the 8's. But I'm deff not saying it wont or cant! It would be a nasty set up in either car for sure!
based on my calculations, the car should do high 8's. I have a friend with a fox body doing 536whp lsx running 9.5 secs..
its not easy but doable i guess.
my buddy has a stock ci ls1 hci procharger d1 and 100 shot vert. vette and he has run 9.3 if i remember correctly, on spray also, i think its 3200ish and has irs still in place.
Love our fox, they're so easy to work on, and they've got a good setup suspension setup for drag. Heck, we're almost in the 9's NA with stock style suspension (rear drag shocks), gutted interior, and a basic built 408 cleveland. Think it's about 2800lbs, still has all the glass, some lexan would really lighten it up some.
