2002 transam
Old 02-04-2010, 11:00 PM
05gmc's Avatar
Default 2002 transam
looking for the best head cam deal to make about 450rwhp im at 380 now with just stock ls6 cam and heads with long tubes
Old 02-05-2010, 09:04 AM
05gmc's Avatar
damn 40 lookers and no response hello lol
Old 02-05-2010, 09:17 AM
jdiddyws6's Avatar
There's alot of options, You could have your heads ported and ditch that cam, or go with some AFR/TFS with a decent cam and handle it.
Old 02-05-2010, 09:21 AM
teke184's Avatar
budget?
manual trans or auto?
TFS 215s if you have the budget.
then any one of a dozen cams off the shelf or custom. something like the Torquer V2, FMS F14, polluter, TRak
you have money for a FAST 92? that will make it alot easier
more budget oriented might call for something like the TFS "as cast" heads, or some TEA LS6 heads
so many options...so many price tags
Old 02-05-2010, 01:54 PM
05gmc's Avatar
auto with 3000 stall
Old 02-06-2010, 09:07 AM
teke184's Avatar
you'll likely need a pretty big cam to do it in an auto.
and with that you'll need a bigger stall...which will make it harder to reach your goals.
best thing is to not get hung up on dyno numbers since its an auto.
put a good cam for your intended use (street, street/strip, strip only), and the best heads you can afford. and a good tune
Old 02-06-2010, 09:11 AM
jdiddyws6's Avatar
Not necessarily. People do it pretty regularly with cams smaller than yours and ported heads.
Old 02-06-2010, 09:36 AM
garygnu's Avatar
PAT-G EPS cam mad 430hp in a stock LS6,415 tq.*222-*226 at.050.in the dyno threads.
