changin oil pan gasket and rear mail seal
Old 02-05-2010, 12:26 AM
droptopT/A's Avatar
Default changin oil pan gasket and rear mail seal
any tips or maybe a write up
Old 02-05-2010, 02:19 AM
bigj2717's Avatar
To do the oil pan gasket you need to lift the motor up so the pan will clear. The rear main seal pull the trans and the clutch flywheel or flex plate depending on what trans you have then pry out the old one with a flat screw driver and gently tap in the new one
Old 02-05-2010, 08:47 PM
droptopT/A's Avatar
what steps do guys use to removing the pan
