10 swap
10 swap
wat would i lose goin to a 10 bolt out of 97 T.A in my 2000 ss, traction control, antilok brakes? and do both rear end have that hole in top
If both are a 3 channel you wont lose anything unless the brakes are indeed different which I think they are. Its not hard to make a 3 channel into a four channel if the current 10 bolt you have is a 4 channel. All you need to do is swap your backing plates and axles into the 3 channel and use the brake lines from your 4 channel and just leave the sensor at the top of the pumkin alone. I just did this and did not lose my ABS or TCS, but I am not sure about a 10 bolt out of an LT1 car.
I have a 10 bolt housing, 3 channel backing plates, axles, and brake lines if you need any of that.
