can i use a 150shot with my 4.11 gears?
i have a head and camed m6 w/4.11's. i am ordering the new nos fuel rail fogger from speed inc,how will my car act on a 150 shot? my tires are 305/40/16 they sit a good inch taller then stock. don't worry,i have the 12bolt and all the other goodies to take the punishment. THANKS,mike c.
Those tires won't stick. I know a lot of people with 315 tire that don't stick. The 150 is doable but I wouldn't count on the engine holding up on the long term. Just make sure the fuel pressure is good.
no problem, but just make sure that you let off before the rearend of the car trys to pass you up. if not you will end up in a ditch. once you get some slicks or et streets, your going to love it. also try not to get to close to the rev limiter or the air lid might blow off, this is very easy to do with 4.11s and a M6.
