Pontiac GTO 2004-2006 - Question
View Full Version : Question
The Silver Goat
02-06-2010, 02:40 PM
I read in a thread somewhere placing the key in the igintion charges the battery in the key.
True or false?
breze84
02-11-2010, 03:26 AM
I dont think so... I have heard someone say that before though....
tom's2005gto
02-11-2010, 06:41 AM
and if you hold the fob at your chin while pointing the key toward your car you get better range with it too.
and, if you hold the t/c button for 30 seconds, you will activate the factory power mod chip in the bcm.
JAX04
02-11-2010, 07:24 AM
Classic. lol
RitcheyRch
02-11-2010, 11:52 AM
Not true and the battery can not be replaced. When the battery dies you need a new fob.
bigredgto
02-11-2010, 12:25 PM
not enitrely true. there's a thread on another forum showing how to replace the battery in the keyfob. it does require some soldering though
and to the OP, there's no truth at all to that. i wish it was true, as then maybe all our key fobs might work better.. but no
tom's2005gto
02-11-2010, 04:17 PM
On a side note, IF you have an after market alarm that is wired up to unlock doors, pop the trunk, etc. then you don't need to worry about a dead battery in your factory fob, as it is only used for such features, not starting the car.
danieloneil01
02-11-2010, 04:51 PM
If I had an aftermarket alarm I sure as hell wouldn't use that gigantic key anymore. lol
tom's2005gto
02-11-2010, 06:13 PM
^^^^ unfortunately, even with an after market alarm, the key & fob are needed to start the car. Although LSPWR is working on something to fix that.
danieloneil01
02-11-2010, 07:05 PM
LOL, good to know.
1904gto
02-12-2010, 01:36 PM
i swear the chin trick works!
