Another C5 brake upgrade
Old 02-06-2010, 05:03 PM
ssteven's Avatar
Default Another C5 brake upgrade
Took about an hour and half. Did the correct bedding for hawk pads. Man do the brakes grab good ....
http://i280.photobucket.com/albums/k...ken2008/c5.jpg
http://i280.photobucket.com/albums/k...en2008/c52.jpg
Got the brackets and rotors from 6liter. Added HPS pads and now its fun time.
Old 02-07-2010, 03:13 PM
ECU_Pirate's Avatar
Collecting the parts to do this myself, only I'm looking at using a C6 front caliper.
Old 02-07-2010, 07:25 PM
spy2520's Avatar
Did you use the C5 caliper brackets?
Edit: nevermind i see it looks like you used all camaro stuff. Those are also camaro pads i'm assuming?
Old 02-09-2010, 05:34 PM
ZexGX's Avatar
C5's have the same calipers as F-bodies in regards to bolting it in. I've heard the casting material/process is different on the C5 calipers though (stronger). You can re-use your F-body calipers when doing a C5 brake conversion, or you can upgrade to the stronger C5 calipers if you are going to be abusing your brakes and want a little more time before the calipers warp/fail. I could be wrong about the stronger part though. They could be lighter and stronger, or lighter and weaker. I do know the only difference is in the material/casting.
Old 02-09-2010, 05:42 PM
InsaneAuto86's Avatar
That's what I have!
Old 02-10-2010, 12:15 AM
Black02SLPSS's Avatar
Originally Posted by InsaneAuto86
That's what I have!
Pics or BAN!!!
Old 02-10-2010, 08:58 AM
Brakemotive's Avatar
C5 Caliper = C6 Caliper with different script, unless your talking Z06 calipers
Old 02-12-2010, 03:07 PM
Kleeborp the Moderator™
MeentSS02's Avatar
From the pics I've seen, the C6 calipers look a little beefier than the C5 calipers - the C5 calipers have the full-width stiffening ribs, and the C6 looks like the entire thing is thicker.
Might not make much of a difference, but who knows...
Old 02-13-2010, 11:30 AM
ECU_Pirate's Avatar
Found a great price on front/rear calipers off of a wrecked 2004 Comm. Edition Z06.
Parts that should be here this week:
Front/rear cross drilled and slotted rotors
Front/rear C5 Z06 calipers
Front/rear pads
I'll track down the adapter brackets this week.
Quick Reply: Another C5 brake upgrade
