speakers dont work
speakers dont work
I just nought a new camaro and the speakers int the doors and sails dont
work but the hatch speakers do work i thought it was the radio so i swapped
it out with a known good radio and no difference then i checked the amp i
unplugged the amp plugged it back in no change. so is it a bad amp?
because i dont believe its a bad connection
have u checked the connections? Same thing happen to me and it turned out to be the connection from when the previous owner decided to "wrap" the speaker wire onto the terminal instead getting quick disconnects or soldering the connection
i have inspected the connections front and back they seem tight and wiggling them pushing in and puling on them has no effect nothing appears to be tampered with it all looks pretty much stock nothing aftermarket at all
the amp has power im sure of that because my backs work. the speakers in
the sail atleast i know are good because i swapped it with the ones in back if
i unplug the amp the backs dont work i know that all the speakers are
powered by the amp and that if the amp is faulty it may not be getting
contact at the harness for whatever reason
Ungrounded Moderator
the amp has power im sure of that because my backs work. the speakers in the sail atleast i know are good because i swapped it with the ones in back if i unplug the amp the backs dont work i know that all the speakers are powered by the amp and that if the amp is faulty it may not be getting contact at the harness for whatever reason
Have you checked the RADIO ACCY fuse? That's the one that protects the Monsoon amp.
ok i swapped out the amp with a good one and same thing so im going to have to say i just have blown speakers all around idk how someone can drive around like that o well you guys have any good suggestions for replacements without spending a ton
