Power steering issue
Hello everyone,
Just installed a Turn One power steering pulley, pump, and reservoir and all of them work great. I also installed a new high pressure line (NAPA) and it seems to work fine as well. However my power steering fluid keeps leaking out, both with the car on and off (more with the car on).
Where the hell could it be leaking from? I don't want to burn out yet ANOTHER power steering pump.
it could be leaking from all the aforementioned parts or the rack itself... clean everything off and see if you can spot the area it's coming from... double check all the fittings/hoses and make sure they are tight and you did install new o-rings i'm assuming??
