How to remove pins?
Old 02-09-2010, 03:31 PM
Pavetim's Avatar
Default How to remove pins?
I'm reworking a harness for my swap and wondered how do you remove the pins/wires from the ecm? Thanks.
Old 02-09-2010, 03:37 PM
46Coupe's Avatar
take the back gray cover off where all the wire come in.
Take off the colored shield thing off the plug side.
Gently push the wire you want to remove forward
Lift the tiny white retainer
Tip the pin slightly up and pull the wire out.
Old 02-09-2010, 04:08 PM
Pavetim's Avatar
Do the colored (red/blue) covers just pull off? And how do you pull the white part up it has that capture bolt with the clip on it.
Old 02-09-2010, 04:14 PM
Pavetim's Avatar
Ok got it, thanks alot.
