Quick Time bellhousing install directions?
Does the bell housing normally come with instructions, or do they assume it should be straightforward? I didn't get any paperwork with mine and no surprise, I'm unsure of how to proceed. It came with bronzed bolts with washers and nuts, and black bolts. So which go where? And I also can't figure out how the motor plate and bellhousing bolt up - does the plate get bolted to the motor first and then the bellhousing? Or do the bolts go through the bellhousing and plate, into the stock holes in the block? Obviously I realize the plate has to go on before the clutch assembly.
Any help is much appreciated...I know I must be missing something, it can't be that hard!
