proshot fogger or sportsman fogger
Old 12-25-2003, 10:18 AM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Default proshot fogger or sportsman fogger
Well the time is here were i need to make a chose between the two kits. I'm looking to run a 200shot.I know the pro shot is good for 500. And the sportsman kit is good for 300.But are those little selonids going to last and if i'm going to run a 200 shot is it worth the extra money buying to proshot system. thanks for any info
Old 12-27-2003, 05:35 PM
tuff's Avatar
I guess if know one knows ill go with the sportsman kit and put rest of the money towards a stand alone fuel system.Hell i might even put a 250 shot threw it.
Old 12-27-2003, 06:02 PM
The Guy in MY 99TA's Avatar
IMO the Pro Shot is the bigger and better system. I like the larger solenoids in ANY case. I'm limited to a 125 shot or so with the little solenoid I'm using in my NX system right now. I want to upgrade to a Pro Shot with the 150 shot jets but I can't exactly afford to do that right now b/c I need a converter, suspension work and some tuning issues solved. SOOO I guess its gunna be a little longer for me!
Josh S.
Old 12-27-2003, 09:13 PM
taqwache's Avatar
the profogger is the better kit, but at 200HP level, both are going to make the same power. also, another thing to remeber is that NOS rates there kits at the motor, not the wheels so if you what to get 200-250 to the wheels, you might be better with the proshot. i know i will try to get one this year. hehehehe.
Quick Reply: proshot fogger or sportsman fogger
